Re: 354 Hemi Transmission Question?
[Re: JohnRR]
#244661
03/06/09 12:53 AM
03/06/09 12:53 AM
Posts: 1,719 Middle of the mitten
69DodgeCharger
Depends on what he wants , there are adaptors that will bolt chevy trans to the motor , and i think the small block 727 is a closer fit ?
The motorhome trans will need a new mainshaft and tailshaft housing for use in a car .
Dave,
According to the 61-71 Dodge sweptline site the small block 727 is a direct bolt on, with the use of a B&M flexplate, if I remember right. And yes there are adaptors available to mount a Chevy tranny to it. As far as the output shaft and driveshaft it is not an issue. This is going into a 1949 Chevy panel truck "monster" 4 wheeler with 44" tires for use at the sand dunes on Michigan's west coast. Once again thanks to all for the info.
[Re: 69DodgeCharger]
#244662
03/06/09 12:36 PM
03/06/09 12:36 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
The SB trans is the closest. Those motors have the crank a little bit longer and a thin adapter factory, but the factory adapter won't work either. The reason there is the dial pins are in a different location to.
QEC(I think that's the name of his company....been around for a long time),TRWATERS, HOT HEADS & PAW as the adapters too.
Moparlee
