354 Hemi Transmission Question? #244656
03/05/09 11:56 PM
03/05/09 11:56 PM
Middle of the mitten
69DodgeCharger Offline OP
Hi all,
I have a friend that is interested in buying the big block 727 transmission out of a motor home I am parting to mate up behind his 354 hemi. Obviously the question is whether or not it is a direct bolt on application, aside from any crankshaft pilot hole/torque converter hub issues. He has his own machine shop and access to even more advanced machining operations so modification/fabrication is not an issue. Thanks in advance for any info on this.
Re: 354 Hemi Transmission Question? [Re: 69DodgeCharger] #244657
03/05/09 11:58 PM
03/05/09 11:58 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
no , it's not a direct bolt on
Re: 354 Hemi Transmission Question? [Re: JohnRR] #244658
03/06/09 12:23 AM
03/06/09 12:23 AM
Allright then, Is it even worth pursuing on his part. As I said before machining and fabrication is not an issue.
Re: 354 Hemi Transmission Question? [Re: 69DodgeCharger] #244659
03/06/09 12:32 AM
03/06/09 12:32 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
392 354 are based on the A block
I believe a SB 727 will bolt on, and if not, somone will ceratinly correct me
Re: 354 Hemi Transmission Question? [Re: 69DodgeCharger] #244660
03/06/09 12:34 AM
03/06/09 12:34 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Depends on what he wants , there are adaptors that will bolt chevy trans to the motor , and i think the small block 727 is a closer fit ?
The motorhome trans will need a new mainshaft and tailshaft housing for use in a car .
Re: 354 Hemi Transmission Question? [Re: JohnRR] #244661
03/06/09 12:53 AM
03/06/09 12:53 AM
Dave,
According to the 61-71 Dodge sweptline site the small block 727 is a direct bolt on, with the use of a B&M flexplate, if I remember right. And yes there are adaptors available to mount a Chevy tranny to it. As far as the output shaft and driveshaft it is not an issue. This is going into a 1949 Chevy panel truck "monster" 4 wheeler with 44" tires for use at the sand dunes on Michigan's west coast. Once again thanks to all for the info.
Re: 354 Hemi Transmission Question? [Re: 69DodgeCharger] #244662
03/06/09 12:36 PM
03/06/09 12:36 PM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
The SB trans is the closest. Those motors have the crank a little bit longer and a thin adapter factory, but the factory adapter won't work either. The reason there is the dial pins are in a different location to.
QEC(I think that's the name of his company....been around for a long time),TRWATERS, HOT HEADS & PAW as the adapters too.
Moparlee
Re: 354 Hemi Transmission Question? [Re: Robbins] #244663
03/06/09 01:55 PM
03/06/09 01:55 PM
michigan
black64 Offline
black64  Offline
michigan
If you have access to machine shop you can make the adapter. it puts the bolts for the trans in the correct location plus spaces the trans back to fit properly. This is a paw unit for a chevy trans there are similar for 727.
Re: 354 Hemi Transmission Question? [Re: 69DodgeCharger] #244664
03/06/09 06:25 PM
03/06/09 06:25 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
The problem with mating a 727 to any '61 and earlier V8 is the crank flange, the early flange extends further from the block, has 8 bolts and registers the flywheel/flexplate differently. Most Hemi-to-727 adapters are fairly thick in order to space the trans back and correct the bolt pattern.
In the pic below the crank in the background is the earlier with the extended flange.
Re: 354 Hemi Transmission Question? [Re: dave571] #244665
03/07/09 04:58 PM
03/07/09 04:58 PM
dogdays Offline
dogdays  Offline
Actually the A block has a lot in common with its EARLIER relation, the Firepower Hemi. So you could say the A/LA block is based on the Firepower.
A smallblock transmission is nearly a direct fit, needs only a little adapter plate stuff. Ask TR Waters.
The motorhome 727 has beefy gts and you may want to put them in a 727 behind a 354, but remember a 354 is the same displacement size as a 360.
R.
