Page 1 of 2 1 2 >
#2444994 - 02/01/18 10:22 PM Making progress on TKO install
dfsmopars Offline
Loc: Kentucky
Purchased a conversion kit from SST to take my ‘72 Charger from A/T to five speed M/T. It’s slow at two or three hours at a time here and there but the pedals and clutch master cylinder are in. Steering column is been converted. Time to confirm some measurements for the clutch disc clearance then it should be time to cut the tunnel. By far the biggest upgrade for me to date.
#2445089 - 02/02/18 06:00 AM Re: Making progress on TKO install [Re: dfsmopars]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
Cool, and OD manual is fun!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 Subaru WRX - E30 Tune ~320whp
#2445121 - 02/02/18 08:46 AM Re: Making progress on TKO install [Re: dfsmopars]
lockjaw-express Offline
Loc: Ohio
Let’s see some pictures of your install progress!
#2445170 - 02/02/18 10:16 AM Re: Making progress on TKO install [Re: lockjaw-express]
dfsmopars Offline
Loc: Kentucky
Master cylinder mounted
#2445171 - 02/02/18 10:18 AM Re: Making progress on TKO install [Re: lockjaw-express]
dfsmopars Offline
Loc: Kentucky
Pedal connected
#2445347 - 02/02/18 05:12 PM Re: Making progress on TKO install [Re: dfsmopars]
5.7L Hemi, 6spd
Loc: Texas
You likely received another bracket to go from the master cyl mounting bolt down to the frame to keep the firewall deflecting. My kit from sst included that.
#2445415 - 02/02/18 08:27 PM Re: Making progress on TKO install [Re: GoodysGotaCuda]
dfsmopars Offline
Loc: Kentucky
You’re right. Probably needs to be the next step. BTW is there supposed to be a rubber seal or something for the side of the bellhousing? There’s like a 3x3 hole where linkage or hose feeds through. Getting ready to take the finger/bearing clearance measurements and just thought about it.
#2445426 - 02/02/18 08:57 PM Re: Making progress on TKO install [Re: dfsmopars]
5.7L Hemi, 6spd
Loc: Texas
My kit came with a giant rectangular grommet I didn't use on my T56. It may be a TKO grommet.
#2446106 - 02/04/18 08:15 AM Re: Making progress on TKO install [Re: dfsmopars]
goldduster318 Offline
Loc: Lake Orion, MI
Wow that master cylinder setup is a lot nicer than the American Powertrain ones I've seen. Doing a T56 Magnum swap on my Duster this year as well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
#2446199 - 02/04/18 11:00 AM Re: Making progress on TKO install [Re: goldduster318]
dfsmopars Offline
Loc: Kentucky
It’s a Wilwood cylinder. This is my first experience with an install like this so nothing to compare it too but I am pleased with this part of the set up so far. Reservoir is in and the brace to prevent the firewall flex.
#2449909 - 02/10/18 10:59 PM Re: Making progress on TKO install [Re: dfsmopars]
dfsmopars Offline
Loc: Kentucky
Update pictures
#2450221 - 02/11/18 04:12 PM Re: Making progress on TKO install [Re: dfsmopars]
dfsmopars Offline
Loc: Kentucky
I don’t know if anyone else can see the pictures but all I see are file names.
#2450259 - 02/11/18 05:19 PM Re: Making progress on TKO install [Re: dfsmopars]
Supercuda Offline
I want my mommy!!
Loc: up yours
I see them, clean work
Don't be the exception.
#2450276 - 02/11/18 05:51 PM Re: Making progress on TKO install [Re: dfsmopars]
boydsdodge Offline
Loc: Toronto, Ont, Canada
I don't see any pics, just a question mark.
I am doing this install on my Challenger, as soon as it gets back in here.
All done but the bell housing alignment, PITA. I am out on the horizontal as well as vertical.
Does SST supply a new bell housing or a modified stock unit?
My kit is one of the last from Keisler.
#2450296 - 02/11/18 06:31 PM Re: Making progress on TKO install [Re: dfsmopars]
dfsmopars Offline
Loc: Kentucky
The kit SST sent to me had a Quick Time bell housing. I did not have any issues with aligning it.
#2454435 - 02/20/18 05:49 AM Re: Making progress on TKO install [Re: dfsmopars]
dfsmopars Offline
Loc: Kentucky
Tunnel is tacked in. Patch is prepared.
#2455966 - 02/22/18 11:14 PM Re: Making progress on TKO install [Re: dfsmopars]
MadMatt Offline
Loc: Meridian, ID
Here's a link to a video I made of a TKO-600 install in my 70 Dart. The BEST mod I ever did! It was super tight on an A-body, but so glad I did it.
https://www.youtube.com/watch?v=5n67-K41YkA
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
#2456039 - 02/23/18 07:56 AM Re: Making progress on TKO install [Re: MadMatt]
dfsmopars Offline
Loc: Kentucky
Big difference in the a body clearance and this third gen b body for sure.
#2458718 - 02/28/18 12:56 AM Re: Making progress on TKO install [Re: goldduster318]
DAYCLONA Online   content
Loc: Mass
That's the Keisler/Wilwood design that SST has carried over in it's line up, I've converted my TKO equipped vehicles over to that master set up, as well as a few customers vehicles, proven very reliable with ZERO issues, and many years/miles of use...
#2460111 - 03/02/18 05:30 PM Re: Making progress on TKO install [Re: dfsmopars]
dfsmopars Offline
Loc: Kentucky
Tunnel is completely in with Dynaliner. Trans is in with oil. Drive shaft is ordered. Gotta wire in neutral and reverse switches, bleed matster cylinder, install steering column and carpet and done.
Page 1 of 2 1 2 >
25,740 Registered Members
192,866 Topics
red line dash ammeter by pass
by moparpro
Today at 10:18 AM
Beautiful A12 RR
by 65pacecar
Today at 08:58 AM
518 trans 46rE
by Frankenduster
Today at 04:14 AM
1969 Plymouth Road Runner RM21
by tomsjack
Today at 02:10 AM
