Making progress on TKO install #2444994
02/02/18 01:22 AM
02/02/18 01:22 AM
Kentucky
dfsmopars Offline OP
Kentucky
Purchased a conversion kit from SST to take my ‘72 Charger from A/T to five speed M/T. It’s slow at two or three hours at a time here and there but the pedals and clutch master cylinder are in. Steering column is been converted. Time to confirm some measurements for the clutch disc clearance then it should be time to cut the tunnel. By far the biggest upgrade for me to date.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring
‘14 Big Horn, Quad Cab, 4x4, 1500
Re: Making progress on TKO install [Re: dfsmopars] #2445089
02/02/18 09:00 AM
02/02/18 09:00 AM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Cool, and OD manual is fun!
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: Making progress on TKO install [Re: dfsmopars] #2445121
02/02/18 11:46 AM
02/02/18 11:46 AM
Ohio
lockjaw-express Offline
Ohio
Let’s see some pictures of your install progress!
Re: Making progress on TKO install [Re: lockjaw-express] #2445170
02/02/18 01:16 PM
02/02/18 01:16 PM
Kentucky
Kentucky
Master cylinder mounted
Re: Making progress on TKO install [Re: lockjaw-express] #2445171
02/02/18 01:18 PM
02/02/18 01:18 PM
Kentucky
Kentucky
Pedal connected
Re: Making progress on TKO install [Re: dfsmopars] #2445347
02/02/18 08:12 PM
02/02/18 08:12 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
You likely received another bracket to go from the master cyl mounting bolt down to the frame to keep the firewall deflecting. My kit from sst included that.
2020 RAM 1500
Re: Making progress on TKO install [Re: GoodysGotaCuda] #2445415
02/02/18 11:27 PM
02/02/18 11:27 PM
Kentucky
Kentucky
You’re right. Probably needs to be the next step. BTW is there supposed to be a rubber seal or something for the side of the bellhousing? There’s like a 3x3 hole where linkage or hose feeds through. Getting ready to take the finger/bearing clearance measurements and just thought about it.
Re: Making progress on TKO install [Re: dfsmopars] #2445426
02/02/18 11:57 PM
02/02/18 11:57 PM
Texas
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
My kit came with a giant rectangular grommet I didn't use on my T56. It may be a TKO grommet.
2020 RAM 1500
Re: Making progress on TKO install [Re: dfsmopars] #2446106
02/04/18 11:15 AM
02/04/18 11:15 AM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
Wow that master cylinder setup is a lot nicer than the American Powertrain ones I've seen. Doing a T56 Magnum swap on my Duster this year as well.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: Making progress on TKO install [Re: goldduster318] #2446199
02/04/18 02:00 PM
02/04/18 02:00 PM
Kentucky
Kentucky
It’s a Wilwood cylinder. This is my first experience with an install like this so nothing to compare it too but I am pleased with this part of the set up so far. Reservoir is in and the brace to prevent the firewall flex.
Re: Making progress on TKO install [Re: dfsmopars] #2449909
02/11/18 01:59 AM
02/11/18 01:59 AM
Kentucky
Kentucky
Update pictures
30388954-6D8D-4561-9CC7-0A913A672444.jpeg26DD90A6-2896-48EE-8CB5-050AA12BD9E2.jpeg2139E081-0D4E-4430-ACC3-A90F07FCFF7A.jpeg
Re: Making progress on TKO install [Re: dfsmopars] #2450221
02/11/18 07:12 PM
02/11/18 07:12 PM
Kentucky
Kentucky
I don’t know if anyone else can see the pictures but all I see are file names.
Re: Making progress on TKO install [Re: dfsmopars] #2450259
02/11/18 08:19 PM
02/11/18 08:19 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I see them, clean work
Don't be the exception.
Re: Making progress on TKO install [Re: dfsmopars] #2450276
02/11/18 08:51 PM
02/11/18 08:51 PM
Toronto, Ont, Canada
boydsdodge Offline
boydsdodge  Offline
I don't see any pics, just a question mark.
I am doing this install on my Challenger, as soon as it gets back in here.
All done but the bell housing alignment, PITA. I am out on the horizontal as well as vertical.
Does SST supply a new bell housing or a modified stock unit?
My kit is one of the last from Keisler.
Re: Making progress on TKO install [Re: dfsmopars] #2450296
02/11/18 09:31 PM
02/11/18 09:31 PM
Kentucky
Kentucky
The kit SST sent to me had a Quick Time bell housing. I did not have any issues with aligning it.
Re: Making progress on TKO install [Re: dfsmopars] #2454435
02/20/18 08:49 AM
02/20/18 08:49 AM
Kentucky
Kentucky
Tunnel is tacked in. Patch is prepared.
Re: Making progress on TKO install [Re: dfsmopars] #2455966
02/23/18 02:14 AM
02/23/18 02:14 AM
Nampa, ID
MadMatt Offline
MadMatt  Offline
Nampa, ID
Here's a link to a video I made of a TKO-600 install in my 70 Dart. The BEST mod I ever did! It was super tight on an A-body, but so glad I did it.
https://www.youtube.com/watch?v=5n67-K41YkA
Some see the glass as half empty, some see the glass as half full. I just drink straight out of the bottle.
Re: Making progress on TKO install [Re: MadMatt] #2456039
02/23/18 10:56 AM
02/23/18 10:56 AM
Kentucky
Kentucky
Big difference in the a body clearance and this third gen b body for sure.
Re: Making progress on TKO install [Re: goldduster318] #2458718
02/28/18 03:56 AM
02/28/18 03:56 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
That's the Keisler/Wilwood design that SST has carried over in it's line up, I've converted my TKO equipped vehicles over to that master set up, as well as a few customers vehicles, proven very reliable with ZERO issues, and many years/miles of use...
Re: Making progress on TKO install [Re: dfsmopars] #2460111
03/02/18 08:30 PM
03/02/18 08:30 PM
Kentucky
Kentucky
Tunnel is completely in with Dynaliner. Trans is in with oil. Drive shaft is ordered. Gotta wire in neutral and reverse switches, bleed matster cylinder, install steering column and carpet and done.
