Page 1 of 3 1 2 3
Broken pushrod piece ,where does it end up? #2439645
01/23/18 05:52 PM
01/23/18 05:52 PM
APACHE JUNCTION AZ
Joesixpack Offline OP
APACHE JUNCTION AZ
broke a pushrod on my 360,where does that piece usually end up? lifter galley? oil pan? can it interfere with the oil pump/distributor drive shaft?
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439663
01/23/18 06:29 PM
01/23/18 06:29 PM
A Red State
SNK-EYZ Online tonguue
SNK-EYZ  Online Tonguue
A Red State
When you say you "broke a pushrod" what exactly do you mean?
From your pic I see a pushrod missing.
Is that what you're talking about?
They usually end up in the lifter valley under the intake.
Edit:
I see what you're talking about now.
Part of the pushrod is still in the head.
Unless you can get the piece out with a magnet the intake will have to come off.
Hopefully it's in the lifter valley.
You don't want it bouncing around in the engine, that would be bad.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439673
01/23/18 06:48 PM
01/23/18 06:48 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
Looks like the top 2 inches are broke off. Look around in the valley with small flashlight etc, and see if you can fish it out. Not seen them break like that too often.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439680
01/23/18 06:57 PM
01/23/18 06:57 PM
P
Porter67 Offline
Porter67  Offline
P
When they rub they get thin, crack and break in that area.
You might do some more inspection.....
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439708
01/23/18 08:14 PM
01/23/18 08:14 PM
South San Francisco, Ca
70sixpkrt Online content
70sixpkrt  Online Content
I broke a push rod once and it ended up on top of the lifter galley. Pulled off my valley pan and there it was. I got lucky that I found all the 3 pieces.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: Broken pushrod piece ,where does it end up? [Re: Porter67] #2439733
01/23/18 09:22 PM
01/23/18 09:22 PM
Good eye EV2Bird, that does look (too) close.
Re: Broken pushrod piece ,where does it end up? [Re: RapidRobert] #2439750
01/23/18 10:07 PM
01/23/18 10:07 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
yes they have been rubbing the head,mistake by me and engine assembler, they are 3/8s wall pushrods and have a larger cup size on top.the rockers i have are stock cast iron with the interference style adjuster...it has a small ball on them for the 5/16s pushrods small top cup. I have new crane adjusters with the small lock nut and new 5/16s proform chrome moly pushrods. should take care of that problem.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439751
01/23/18 10:11 PM
01/23/18 10:11 PM
P
Porter67 Offline
Porter67  Offline
P
I use thick wall smith brothers 5/16 on #550 open on one build, many use 5/16 pushrods, not so many it seems in the mopar world for some reason.
Im getting to use a set of those rockers, can you post what cam and springs your using?
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439755
01/23/18 10:18 PM
01/23/18 10:18 PM
Washington
madscientist Offline
Washington
You need to correct your rocker geometry.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439776
01/23/18 10:52 PM
01/23/18 10:52 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
pics of removed pushrods
one fell apart when i removed it(tip fell out,bottom is super loose.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439794
01/23/18 11:37 PM
01/23/18 11:37 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
Cam P4529970 mech. 284/284 72 .526/.526 28/32 lash 106 centerline
dont know on springs, came on the 2.02 915Js when i bought them(were new), were checked for spring pressure and the spring heights were set.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2439874
01/24/18 03:00 AM
01/24/18 03:00 AM
If you haven't decided to remove the intake manifold and oil pan to retrieve all the loose pieces, are you feeling really lucky work
Do you really want to take a chance of one of those pieces falling in between the cam and lifters or the in between the cam and block work
I broke a inner valve spring on one of my old bracket motors years ago, it spit the pushrod out and the roller lifter, I took the intake and valley pan off and replace that pushrod, valve spring and that set of lifters and ran it for several more races before selling the car to a guy who had to absolutely have it right then. He raced it for over six months one to two times a month and ended up spinning a rod bearing after loosing the oil pressure and not noticing for two runs shock
A piece of that broken valve spring tip was lodged into the oil pump locking it up shruggy
Murphy loves messing with us drag racers, don't you know whistling
Fix it now properly before running it again up twocents
Re: Broken pushrod piece ,where does it end up? [Re: Cab_Burge] #2439992
01/24/18 01:34 PM
01/24/18 01:34 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
I know ,your correct, problem i have is i now live in a HOA park.,got a slab,no garage, and your not supposed to work on your cars here in view of the noisy&nosy neighbors. lol. trying to figure it out first.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440037
01/24/18 02:47 PM
01/24/18 02:47 PM
Nosy (I'm assuming!)
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440062
01/24/18 03:26 PM
01/24/18 03:26 PM
Courtenay, B.C.
DarrenS Offline
DarrenS  Offline
Courtenay, B.C.
Originally Posted By Joesixpack
I know ,your correct, problem i have is i now live in a HOA park.,got a slab,no garage, and your not supposed to work on your cars here in view of the noisy neighbors. lol. trying to figure it out first.
I had that before. I put up a canvas "car shelter" and problem solved. If that is an option in your area...
Re: Broken pushrod piece ,where does it end up? [Re: DarrenS] #2440075
01/24/18 03:46 PM
01/24/18 03:46 PM
APACHE JUNCTION AZ
APACHE JUNCTION AZ
cant am in middle of street and no room
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440114
01/24/18 04:25 PM
01/24/18 04:25 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I have a couple of messages out to see if someone local can help you out.
Abe Lincoln
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440161
01/24/18 06:07 PM
01/24/18 06:07 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
You will need to have the rocker arms spot faced where the jam nut tightens down or they will loosen up every time you run the engine through it's cycle.
Might be more cost effective to install the "offshore" rockers. With your mild cam and springs you should be OK luck
There's a set of Erson rockers on Ebay right now for $150 and I would bet you couldn't get yours machined for that price twocents
Gus
64 Plymouth Savoy
Dana 60
Re: Broken pushrod piece ,where does it end up? [Re: fourgearsavoy] #2440186
01/24/18 07:00 PM
01/24/18 07:00 PM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
The top where jam nut seats will definitely need to be spot faced. Usually tears up the adjuster threads from cocking the jam nut onto the crooked face. Should only cost around $30/$40 to get it done. The old 273s are way better than the Chinese junk.
Re: Broken pushrod piece ,where does it end up? [Re: Joesixpack] #2440207
01/24/18 08:16 PM
01/24/18 08:16 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
One of the reasons I glue magnets in my oil pan, trans pan and rear end cover.
Page 1 of 3 1 2 3
