Re: Broken pushrod piece ,where does it end up?
[Re: Joesixpack]
#2439663
01/23/18 06:29 PM
01/23/18 06:29 PM
Posts: 10,130 A Red State
SNK-EYZ
A Red State
When you say you "broke a pushrod" what exactly do you mean?
From your pic I see a pushrod missing.
Is that what you're talking about?
They usually end up in the lifter valley under the intake.
Edit: I see what you're talking about now. Part of the pushrod is still in the head.
Unless you can get the piece out with a magnet the intake will have to come off.
Hopefully it's in the lifter valley.
You don't want it bouncing around in the engine, that would be bad.
[Re: Porter67]
#2439733
01/23/18 09:22 PM
01/23/18 09:22 PM
RapidRobert
Good eye EV2Bird, that does look (too) close.
[Re: Joesixpack]
#2439755
01/23/18 10:18 PM
01/23/18 10:18 PM
Posts: 4,457 Washington
madscientist
Washington
You need to correct your rocker geometry.
[Re: Joesixpack]
#2439874
01/24/18 03:00 AM
01/24/18 03:00 AM
Posts: 43,126 Bend,OR USA
Cab_Burge
If you haven't decided to remove the intake manifold and oil pan to retrieve all the loose pieces, are you feeling really lucky Do you really want to take a chance of one of those pieces falling in between the cam and lifters or the in between the cam and block I broke a inner valve spring on one of my old bracket motors years ago, it spit the pushrod out and the roller lifter, I took the intake and valley pan off and replace that pushrod, valve spring and that set of lifters and ran it for several more races before selling the car to a guy who had to absolutely have it right then. He raced it for over six months one to two times a month and ended up spinning a rod bearing after loosing the oil pressure and not noticing for two runs A piece of that broken valve spring tip was lodged into the oil pump locking it up Murphy loves messing with us drag racers, don't you know Fix it now properly before running it again
[Re: Cab_Burge]
#2439992
01/24/18 01:34 PM
01/24/18 01:34 PM
Posts: 11,912 APACHE JUNCTION AZ
Joesixpack
APACHE JUNCTION AZ
I know ,your correct, problem i have is i now live in a HOA park.,got a slab,no garage, and your not supposed to work on your cars here in view of the noisy&nosy neighbors. lol. trying to figure it out first.
[Re: Joesixpack]
#2440062
01/24/18 03:26 PM
01/24/18 03:26 PM
Posts: 588 Courtenay, B.C.
DarrenS
Courtenay, B.C.
I know ,your correct, problem i have is i now live in a HOA park.,got a slab,no garage, and your not supposed to work on your cars here in view of the noisy neighbors. lol. trying to figure it out first. I had that before. I put up a canvas "car shelter" and problem solved. If that is an option in your area...
[Re: Joesixpack]
#2440114
01/24/18 04:25 PM
01/24/18 04:25 PM
Posts: 16,133 Mesa, Arizona
dart4forte
Mesa, Arizona
cant am in middle of street and no room I have a couple of messages out to see if someone local can help you out.
Abe Lincoln
[Re: Joesixpack]
#2440161
01/24/18 06:07 PM
01/24/18 06:07 PM
Posts: 10,552 Rittman Ohio
fourgearsavoy
Rittman Ohio
yes they have been rubbing the head,mistake by me and engine assembler, they are 3/8s wall pushrods and have a larger cup size on top.the rockers i have are stock cast iron with the interference style adjuster...it has a small ball on them for the 5/16s pushrods small top cup. I have new crane adjusters with the small lock nut and new 5/16s proform chrome moly pushrods. should take care of that problem. You will need to have the rocker arms spot faced where the jam nut tightens down or they will loosen up every time you run the engine through it's cycle. Might be more cost effective to install the "offshore" rockers. With your mild cam and springs you should be OK There's a set of Erson rockers on Ebay right now for $150 and I would bet you couldn't get yours machined for that price Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: Joesixpack]
#2440207
01/24/18 08:16 PM
01/24/18 08:16 PM
Posts: 8,233 fredericksburg,va
cudaman1969
fredericksburg,va
One of the reasons I glue magnets in my oil pan, trans pan and rear end cover.
