When you say you "broke a pushrod" what exactly do you mean?
From your pic I see a pushrod missing.
Is that what you're talking about?
They usually end up in the lifter valley under the intake.
Edit:
I see what you're talking about now.
Part of the pushrod is still in the head.
Unless you can get the piece out with a magnet the intake will have to come off.
Hopefully it's in the lifter valley.
You don't want it bouncing around in the engine, that would be bad.
