have had same cam once engine was new and built in 2010
it aint a TA intake offset rocker, i looked and found a pic of those
solid cam and lifters, rockers,pushrods and started out in this 360
yes pushrods were 3/8s tube size, i did not check clearance when i picked up complete engine from the builder, he should have checked during assembly.
7.500 was the length of the 3/8s pushrods
proform 5/16s are 7.500
I determined pushrod length by solid cam,adjustable rockers,and listing for sm mopar. i did look at several brands which all seemed to have different lengths even for the solid cam set up. thanks for all your help.i figured with almost stock block,heads,rockers, etc that off the shelf parts would suffice. I have contacted Mike at B3R and explained the situation. hopefully he can assist me.
Good move. It will be helpful to know what the solution is. Keep us informed.
