03 1500 9 1/4 rear end swap issue #2425105
12/28/17 10:49 PM
12/28/17 10:49 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
My original Sure-grip 9 1/4 rear end blew up a while back, so I swapped the rear end from another 03 truck I had. Both trucks are two-wheel drive. Of course this one had a horrible pinion whine at 45-55 mph. I’ve run it for over a year, but it developed a vibration and the howl went away. I bought another rear from a 4wd ‘03, and the plug for the ABS tone ring is different. Luckily, the wires were cut, so I wired it to existing two wires. Colors were different, so I did the guess. Now my dash ‘Brake’ and ABS lights are on. Switched wires around to no help. Any ideas?
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2425148
12/28/17 11:41 PM
12/28/17 11:41 PM
colorado
savoy64 Offline
savoy64  Offline
colorado
swap the sensor to the original one....
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2425197
12/29/17 01:09 AM
12/29/17 01:09 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Broke it removing the wires...
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2425201
12/29/17 01:17 AM
12/29/17 01:17 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
Buy another one
or
Put a piece of electrical tape over the offending light.
Don't be the exception.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2425436
12/29/17 05:45 PM
12/29/17 05:45 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Because the ABS light is on, no more cruise control...
I guess I’ll get another sensor
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2433148
01/12/18 12:33 AM
01/12/18 12:33 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I replaced the speed sensor with a new one for an ‘03. Replaced the plug with my original. The ABS and brake light are still on. Next step???
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2433167
01/12/18 01:18 AM
01/12/18 01:18 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Disconnect the battery and let it clear the codes. Does the rear axle assembly have abs sensors on it?
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2433343
01/12/18 01:20 PM
01/12/18 01:20 PM
n.c.
geo. Offline
geo.  Offline
n.c.
I don't know the answer to this,
but are all the tone rings the same?
Is it worth taking off the cover and counting the teeth?
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2434310
01/14/18 10:45 AM
01/14/18 10:45 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Disconnected the battery for a minute or so, ABS / brake lights are still on. Didn’t drive it yet, but did notice that when I turned cruise control on, the indicator lit up. Would not do that before. I’ll get it on a code reader and see what it says. The speed sensor that was in this rear end is a 2005 and up, so I guess this rear was changed out in the truck I got it from.
Re: 03 1500 9 1/4 rear end swap issue [Re: geo.] #2434312
01/14/18 10:51 AM
01/14/18 10:51 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I don’t know that either, but they did change the speed sensor style in 05/06. That makes me wonder.
I had the cover off initially, to check condition, and I put $60 worth of Royal Purple gear oil in it. Cover stays on for now.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2434443
01/14/18 03:08 PM
01/14/18 03:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could always save the new fluid and reuse it.
Re: 03 1500 9 1/4 rear end swap issue [Re: stumpy] #2434679
01/14/18 11:00 PM
01/14/18 11:00 PM
Cleveland Ohio
sportfury70 Online content
sportfury70  Online Content
Cleveland Ohio
I believe you need to touch battery cables ends together for approx 15 seconds with headlights on to deplete any memory in computer. I've had to do this with my 07 minivan & also my 2011 ram 1500 to completely clear code.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2434782
01/15/18 01:21 AM
01/15/18 01:21 AM
SoMd, USA
135sohc Offline
135sohc  Offline
SoMd, USA
Key dance to display codes doesnt cost anything.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2434869
01/15/18 06:19 AM
01/15/18 06:19 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
When you connected the rear axle speed sensor wires back together how did you do it?
The correct way per Dodge is to solder them and used heat shrink tubing.
With the low voltage that the sensors use crimp connectors could be an issue.
Re: 03 1500 9 1/4 rear end swap issue [Re: sportfury70] #2435414
01/16/18 02:15 AM
01/16/18 02:15 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
I’ve never heard that before...
Re: 03 1500 9 1/4 rear end swap issue [Re: SNK-EYZ] #2435416
01/16/18 02:16 AM
01/16/18 02:16 AM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Of course I used crimp style connectors...
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2435580
01/16/18 12:56 PM
01/16/18 12:56 PM
Cleveland Ohio
Cleveland Ohio
Ok. I hadn't either. What's it hurt to try it? Worked for me. Makes no difference to me. This is why I generally don't reply.
Re: 03 1500 9 1/4 rear end swap issue [Re: sportfury70] #2437151
01/18/18 10:49 PM
01/18/18 10:49 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Well, I only was saying I’ve never heard that before. Nothing more... and prob will try, can’t hurt!
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2438448
01/21/18 03:30 PM
01/21/18 03:30 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Still haven’t got a code reader on it yet, but I did take terminal off and touched them together for a while. That DID clear my check engine light, but ABS and Brake dash lights are still on.
Re: 03 1500 9 1/4 rear end swap issue [Re: Bull1tt] #2438633
01/21/18 09:16 PM
01/21/18 09:16 PM
Pgh, PA
Bull1tt Offline OP
Bull1tt  Offline OP
Pgh, PA
Plugged in a code reader and it came up “NO CODES” on the OBD II scanner. So now I have no cruise control with these lights on the dash. (ABS / Brake) This rear end has no sensors for ABS, only wires go to speed sensor.
Now what?
