Re-wiring your car questions
#2434168
01/13/18 11:40 PM
01/13/18 11:40 PM
Posts: 10,554 Rittman Ohio
fourgearsavoy
Rittman Ohio
I have been considering re-wiring my Savoy with an updated universal system with fresh wires. Like a lot of our cars the wires and connectors are getting very brittle and and are really not up to the job with added accessories and higher output alternators. I was considering just adding a 5 circuit sub system for my added components or should I just change over the entire system with fresh wires to all components. I have an MSD ignition so that system is very basic and I also have upgraded to a Denso internal regulator alt. so that should also make easier. I just need a basic system to run the lights,wipers,fuel pump,and horn. Thanks in advance Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: Re-wiring your car questions
[Re: topside]
#2434190
01/14/18 12:25 AM
01/14/18 12:25 AM
fourgearsavoy
Rittman Ohio
Yeah I was looking at their products and the Mopar specific system was $999.00 I think I may go with the universal system. Gus
[Re: IMGTX]
#2434223
01/14/18 01:40 AM
01/14/18 01:40 AM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
If you are going to do the whole kit-n-kaboodle yourself it can be a painstaking mess. I will say that is very true. It took me nearly 3 months worth of time to finish wiring my car. Granite I did a from-scratch fuse box and have EFI...but it can be quite extensive. SOLDER ALL CONNECTIONS That you can. Don't skimp on this step.
...this too. Every connection on my car is crimped and soldered.
[Re: fourgearsavoy]
#2434245
01/14/18 02:33 AM
01/14/18 02:33 AM
moparpollack
Lil Herman
Lil Herman
85086
Yeah I was looking at their products and the Mopar specific system was $999.00 I think I may go with the universal system. Gus Start from scratch with Rapidroberts help. When I wired my 39 Plymouth pick up he broke it down and made the job easier. Learned a lot and it wasn't that hard.
[Re: moparpollack]
#2434375
01/14/18 01:12 PM
01/14/18 01:12 PM
fourgearsavoy
Rittman Ohio
Well I've been doing wiring for over 30 years and I used to wire complete utility trucks with man lifts,cable pullers,generators etc. so I know how to wire a vehicle.I should probably re-phrase my question to "what kit do you guys like to use" There are at least a hundred differn't universal kits out there made in a dozen countries. All I need is just a basic deal with enough circuits to be legal for road use. Just asking what have you used and what were the problems you had with various kits so I know what works best. Thanks for all the information so far. Gus
[Re: moparpollack]
#2434378
01/14/18 01:18 PM
01/14/18 01:18 PM
Posts: 19,408 north of coder
moparx
gus, a simple, basic system, can sometimes be better going one wire at a time. that is, if you are not in a huge hurry, and want to learn a lot about the circuits present. what ever you decide, and i can't emphasize this enough, use QUALITY wire, terminals, and crimping tools ! solder if you wish, but don't OVER DO it on the solder, making it a brittle joint. there is a reason the OEM's crimp 95% of all connections. marine shrink tube with the adhesive is all i recommend when shrink tube is required on a termination or a splice. keep as many factory style plugs as you can when plugging in components, and protect your harness with proper routing and grommets, then the outer sheaving can be what ever you choose, as there are multiple choices available. i, however, dislike the late model plastic split loom cover that comes in a bunch of colors ! but that's just me. take a little time and you can do a GREAT job, it's not that hard ! just don't do anything like this mess i had to fix one time !
[Re: fourgearsavoy]
#2434483
01/14/18 04:35 PM
01/14/18 04:35 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
I've used "Ron Frances", "It's a Snap", and "Keep it Clean" wiring kits and they all were pretty easy. That said, I would NEVER use a "Ron Frances" kit again simply because they use a proprietary solid state fuse panel that only they can fix.
I'm currently wiring my '64 Polara with the "Keep it Clean" kit. This is big block 4 speed car that has a Vintage Air kit installed. This kit is one of their "bare bones kits" that is basically just the fuse panel and associated wiring and does not include the wiring for most of the car. It was cheap (under $100 on sale) and if you purchase the rest of the wire and connectors yourself its still a good deal. However, there is no way I would recommend this kit for a beginner.
The best of the three in my opinion was the "It's a Snap" 18 circuit kit. I used this one on a '53 Chebby pickup I built that was early hemi powered and had a Hot Rod Air AC unit installed. I also used it on my 32 Ford 3 window coupe. This kit is pretty complete, has good directions, and is pretty much a piece of cake to install.
Hope this helps.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: fourgearsavoy]
#2434485
01/14/18 04:38 PM
01/14/18 04:38 PM
Posts: 15,376 Omaha Ne
TJP
Omaha Ne
Well I've been doing wiring for over 30 years and I used to wire complete utility trucks with man lifts,cable pullers,generators etc. so I know how to wire a vehicle.I should probably re-phrase my question to "what kit do you guys like to use" There are at least a hundred differn't universal kits out there made in a dozen countries. All I need is just a basic deal with enough circuits to be legal for road use. Just asking what have you used and what were the problems you had with various kits so I know what works best. Thanks for all the information so far. Gus American Autowire, their Hiway series kits sound like exactly what you need.
[Re: fourgearsavoy]
#2434829
01/15/18 03:37 AM
01/15/18 03:37 AM
Posts: 1,260 New Mexico
Adobedude
New Mexico
Don't solder, use the proper sized quality terminals and crimpers. A bad solder joint, which is wàaaaay to easy to do will be brittal, ask guys who work on airplanes.
2001 Dodge Dakota 408 All Motor 11.27 @ 117.83 mph 2017 NM Mopar Challenge Series Champion.
[Re: Adobedude]
#2434855
01/15/18 05:17 AM
01/15/18 05:17 AM
Posts: 43,193 Bend,OR USA
Cab_Burge
Don't solder,, ask guys who work on airplanes. I owned and worked on my own airplane for 15 years under the direct supervision of a A&P and Inspector authorized designated engineer. The main reason they don't use solder connections on factory airplanes is weight and wire gauge size as well as the airplane flying in all kinds of weather with massive air temp changes and vibration I worked for the local phone company for over 33 yrs, we solder every permanent connections in the equipment offices and on all the inter connection wiring on most of the wires. If you solder and heat shrink the connections properly and make sure they aren't moving around a bunch you will be fine, as I'm sure Gus already knows that
[Re: fourgearsavoy]
#2435187
01/15/18 08:25 PM
01/15/18 08:25 PM
Posts: 1,099 Massillon, Ohio
cudatom
Massillon, Ohio
I've used two different kits. My Cuda has an ARC kit. Super simple and I reàlly like their set up. Plenty of wire, nice directions as well as options.
The second was a Painless kit that went in my wagon. What a POS. I would never use them again. Wire was cheap, poor connections and their suggested wiring diagram was crap.
Ok
[Re: cudatom]
#2435279
01/15/18 10:58 PM
01/15/18 10:58 PM
fourgearsavoy
Rittman Ohio
Well I'm leaning to the American Hiway series but if the Keep It Clean site was better I might use them but I will check them out by phone. Thanks again for all the responses BTW I always crimp,solder,shrink ALL connections unless they are shock mounted. Gus
