383-440 engine swap on 70 Cuda-4speed Shaker Help! #2433701
01/13/18 01:00 AM
01/13/18 01:00 AM
Ontario. Canada
SunnyMopar Offline OP
Ontario. Canada
Hello, I am new on this forum!
Iam trying to swap a 383 to 440 for my e-body:
1970 Cuda- Shaker 4-speed
Has anyone done this before!
Would like to know what i need to replace to have the 440 swap in!
Exp.., fuel lines, throtle linkage, distributer Bell housing , flywheel, Clutch., . ect part needed to complete swap!
Please help! MoparSonny!
Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar] #2433702
01/13/18 01:01 AM
01/13/18 01:01 AM
Ontario. Canada
Ontario. Canada
MoparSonny
Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar] #2433708
01/13/18 01:21 AM
01/13/18 01:21 AM
Sonny welcome here! is there a SB in there now? what yr is the 440?
Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: RapidRobert] #2433731
01/13/18 02:15 AM
01/13/18 02:15 AM
Ontario. Canada
Ontario. Canada
383 block is in there now in the 1970-Cuda! want to swap with a 1968-69 440 block!
Need to know what obstecles i will face!.. any info is gratefull
Thanks , Rapid Robert
Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar] #2433744
01/13/18 02:47 AM
01/13/18 02:47 AM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Three things I can think of. The pilot bearing and the shaker will need attention. The exhaust might need a little rearranging. Possible throttle bracket?
Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar] #2433923
01/13/18 03:06 PM
01/13/18 03:06 PM
central il.
second 70 Offline
second 70  Offline
central il.
Sonny if it’s only the block you have you’re going to need a new intake,shaker base, distributor, and maybe exhaust. The headers fit so much easier on a 383 because with the higher deck of the 440 it puts them right against the bottom of the car.
