#2433701 - 01/12/18 10:00 PM 383-440 engine swap on 70 Cuda-4speed Shaker Help!
SunnyMopar Offline
Loc: Ontario. Canada
Hello, I am new on this forum!
Iam trying to swap a 383 to 440 for my e-body:
1970 Cuda- Shaker 4-speed
Has anyone done this before!
Would like to know what i need to replace to have the 440 swap in!
Exp.., fuel lines, throtle linkage, distributer Bell housing , flywheel, Clutch., . ect part needed to complete swap!
Please help! MoparSonny!
#2433702 - 01/12/18 10:01 PM Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar]
SunnyMopar Offline
MoparSonny
#2433708 - 01/12/18 10:21 PM Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar]
Loc: Lincoln Nebraska
Sonny welcome here! is there a SB in there now? what yr is the 440?
#2433731 - 01/12/18 11:15 PM Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: RapidRobert]
SunnyMopar Offline
383 block is in there now in the 1970-Cuda! want to swap with a 1968-69 440 block!
Need to know what obstecles i will face!.. any info is gratefull
Thanks , Rapid Robert
#2433744 - 01/12/18 11:47 PM Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar]
Dave Hall Offline
Loc: Cotati, CA
Three things I can think of. The pilot bearing and the shaker will need attention. The exhaust might need a little rearranging. Possible throttle bracket?
#2433923 - 01/13/18 12:06 PM Re: 383-440 engine swap on 70 Cuda-4speed Shaker Help! [Re: SunnyMopar]
second 70 Offline
Loc: central il.
Sonny if it’s only the block you have you’re going to need a new intake,shaker base, distributor, and maybe exhaust. The headers fit so much easier on a 383 because with the higher deck of the 440 it puts them right against the bottom of the car.
25,540 Registered Members
194,185 Topics
Holley Dominator Fuel Pumps
by blairboy3
10/23/18 11:00 PM
Trick Flow manifold and hood clearance B body
by frank
10/23/18 09:50 PM
Mclaren aluminum blocks
by Stewart
10/23/18 09:47 PM
Wood trailer floor...............
by Michael
10/23/18 08:21 PM
