can old Cragars be rechromed?
#2432277
01/10/18 04:21 PM
01/10/18 04:21 PM
Posts: 7,491 Minnesota
Hemi_Joel
Minnesota
I can get a set made in 1972. They have some minor rust where the center meets the hoop. Is it worth it, or are new Cragars identical?
Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: can old Cragars be rechromed?
[Re: Hemi_Joel]
#2432294
01/10/18 04:41 PM
01/10/18 04:41 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
I doubt you'll find a shop willing to do it. I expect even if you do you'll find it makes the cost of new attractive. It's a shame, IIRC, Cragar didn't move production out of the U.S. until ~ 1975? Went to Brazil then? Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Hemi_Joel]
#2432296
01/10/18 04:41 PM
01/10/18 04:41 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
(Wheel&Tire shop right down the street here can do anything you want to an old set of rims... $$$...
[Re: Hemi_Joel]
#2432776
01/11/18 01:20 PM
01/11/18 01:20 PM
Posts: 4,431 Michigan
MarkZ
Worthy
Worthy
My Dad bought a set of brand new Cragars for his car a few years ago. Inside of a year they started rusting and this was on a garage kept fair weather driver. Car maybe saw 1,000 miles that year. I don't know if their QC has gotten any better since then.
[Re: autoxcuda]
#2432814
01/11/18 02:50 PM
01/11/18 02:50 PM
Posts: 25,849 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You just cut the center from the outer casing.
Then re chrome both
And last weld them back together. There are steel inserts in the aluminum center that you weld to. This is a common deal. Here's a pic of the Cragar center/rim weld. As stated, simply cut the weld and separate the pieces for plating.
[Re: Hemi_Joel]
#2432864
01/11/18 04:22 PM
01/11/18 04:22 PM
Posts: 8,848 poplar bluff mo.
toplescuda
I Whine
I Whine
poplar bluff mo.
The old centers are also steel. I had old cragers and the whole wheel was rusted and peeling. If you buy new ones. They will also be rusted soon Iv had ralley wheels powder coated. And the problem is. It's hard the get the seam where hoop and center meet not clump up. And when in the oven it will pop. In order to re chrome. The old has to be removed. Lots of money. And few years will look same if not worse then the wheel you have now ....ya couldn't give me a set of "chrome" wheels
1970 barracuda convert. 1 of 59 1970 pro street A.A.R. clone (panther pink) 1971 charger 2015 hellcat challenger. Redline red 2014 quad cab 4x4 ram 8 speed hemi
[Re: toplescuda]
#2432882
01/11/18 05:00 PM
01/11/18 05:00 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
I love Cragar wheels. Yes, they rust if you sneeze near them. I have had mine which I bought used at a flea market in the 80's still look good enough for a driver today. I usually rub wax all over them & let the wax sit on them all winter long & then wipe off in the spring but just realized I did not do that this winter, ooops.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Hemi_Joel]
#2432899
01/11/18 05:26 PM
01/11/18 05:26 PM
Posts: 8,285 fredericksburg,va
cudaman1969
fredericksburg,va
Cragars where THE wheel back in the day. First thing after buying the car was installing Cragars. Not necessarily in this order but English Leather, Right Guard and Cragars where it.
[Re: Hemi_Joel]
#2432905
01/11/18 05:32 PM
01/11/18 05:32 PM
Posts: 27,468 So Cal
autoxcuda
So Cal
I had my spyder rim centers cut from the outer casing for $20/rim. Then I can detail the centers myslef and have them put new chrome outers on at my preferred backspacing.
It's about $85-100 total with new chrome off the shelf production outers per rim. If I had the centers chrome, that would be a separate extra cost that I would have to handle myself.
[Re: cudaman1969]
#2432915
01/11/18 05:45 PM
01/11/18 05:45 PM
John_Kunkel
Rio Linda, CA
Cragrars (sic) where THE wheel back in the day. They still are to a lot of us dinosaurs.
