can old Cragars be rechromed? #2432277
01/10/18 04:21 PM
01/10/18 04:21 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I can get a set made in 1972. They have some minor rust where the center meets the hoop.
Is it worth it, or are new Cragars identical?
Thanks,
Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432291
01/10/18 04:39 PM
01/10/18 04:39 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
You might be better off and cheaper off to have them powder coated in chrome color. I have seen some done and it looks like real chrome!! Wont peel or discolor too! up
Stu
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432294
01/10/18 04:41 PM
01/10/18 04:41 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
I doubt you'll find a shop willing to do it. I expect even if you do you'll find it makes the cost of new attractive. It's a shame, IIRC, Cragar didn't move production out of the U.S. until ~ 1975? shruggy Went to Brazil then?
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432296
01/10/18 04:41 PM
01/10/18 04:41 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Originally Posted By Hemi_Joel
Is it worth it
(Wheel&Tire shop right down the street here can do anything you want to an old set of rims...
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432302
01/10/18 04:51 PM
01/10/18 04:51 PM
Minnesota
Minnesota
These would be for the Hemi Blues.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432319
01/10/18 05:26 PM
01/10/18 05:26 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
Joel, I just bought these brand new from Summit about a year ago. 15 x 4 1/2 with the correct direct bolt pattern. The center caps are definitely not the same at the originals so I changed them out with some nice originals. I have heard that the spokes may be “flatter” on the new Cragars but I cannot verify that.
After taking these photos, I see that I need to take a few minutes and clean the car... It is getting dirty. I have been driving it a lot!
Stan
3E1CC6BE-2434-452F-8FA0-51B3E1D62780.jpegCA6D63E5-C768-44D7-8D23-E630E32F29F0.jpegD22DD843-DB9B-4C2B-9B0E-5FE51A2CBA28.jpeg
Re: can old Cragars be rechromed? [Re: HemiStan] #2432364
01/10/18 06:51 PM
01/10/18 06:51 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Too hard to get the chrome down in the seam is the issue. Likely cheaper to buy new ones as chrome plating prices are steep.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432383
01/10/18 07:23 PM
01/10/18 07:23 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
If it was done originally, why can't it be done again?
I have a set of the 15x4-1/2 that wanted to have done also, just haven't got around to checking. Then get a set of 8 or10" reversed to widen to 14" for the back, nostalgic look.
The powder coating red or gold is an idea though. Black car.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432396
01/10/18 07:49 PM
01/10/18 07:49 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You just cut the center from the outer casing.
Then re chrome both
And last weld them back together. There are steel inserts in the aluminum center that you weld to. This is a common deal.
Before
After
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432403
01/10/18 08:00 PM
01/10/18 08:00 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
You can't imagine what they would charge you.
2011 Drag Pak Challenger
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432477
01/10/18 10:11 PM
01/10/18 10:11 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
If you decide to go new, I believe that Cragar offers their rims in drilled now so that you don't have to go to Uni-Lug. I have never had any problems with Uni-Lug rims. I just don't like the way they look and they are a much bigger pain to install.
twocents
Master, again and still
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432614
01/11/18 01:59 AM
01/11/18 01:59 AM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Check on plating prices first but do it setting down. I got an estimate of $175 for a 64 callout hood ornament. It was in decent shape and didn't need any filling. A friend in Michigan had the five letters (D-O-D-G-E) done for his Charger restoration. He paid $100 each.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432776
01/11/18 01:20 PM
01/11/18 01:20 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
My Dad bought a set of brand new Cragars for his car a few years ago. Inside of a year they started rusting and this was on a garage kept fair weather driver. Car maybe saw 1,000 miles that year. I don't know if their QC has gotten any better since then.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432791
01/11/18 02:05 PM
01/11/18 02:05 PM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Re: can old Cragars be rechromed? [Re: autoxcuda] #2432814
01/11/18 02:50 PM
01/11/18 02:50 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Then re chrome both
Here's a pic of the Cragar center/rim weld. As stated, simply cut the weld and separate the pieces for plating.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432864
01/11/18 04:22 PM
01/11/18 04:22 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
The old centers are also steel. I had old cragers and the whole wheel was rusted and peeling. If you buy new ones. They will also be rusted soon
Iv had ralley wheels powder coated. And the problem is. It's hard the get the seam where hoop and center meet not clump up. And when in the oven it will pop. In order to re chrome. The old has to be removed. Lots of money. And few years will look same if not worse then the wheel you have now
....ya couldn't give me a set of "chrome" wheels
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: can old Cragars be rechromed? [Re: toplescuda] #2432882
01/11/18 05:00 PM
01/11/18 05:00 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I love Cragar wheels. Yes, they rust if you sneeze near them. I have had mine which I bought used at a flea market in the 80's still look good enough for a driver today. I usually rub wax all over them & let the wax sit on them all winter long & then wipe off in the spring but just realized I did not do that this winter, ooops.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432899
01/11/18 05:26 PM
01/11/18 05:26 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Cragars where THE wheel back in the day. First thing after buying the car was installing Cragars. Not necessarily in this order but English Leather, Right Guard and Cragars where it.
Re: can old Cragars be rechromed? [Re: Hemi_Joel] #2432905
01/11/18 05:32 PM
01/11/18 05:32 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
I had my spyder rim centers cut from the outer casing for $20/rim. Then I can detail the centers myslef and have them put new chrome outers on at my preferred backspacing.
It's about $85-100 total with new chrome off the shelf production outers per rim. If I had the centers chrome, that would be a separate extra cost that I would have to handle myself.
Re: can old Cragars be rechromed? [Re: cudaman1969] #2432915
01/11/18 05:45 PM
01/11/18 05:45 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By cudaman1969
Cragrars (sic) where THE wheel back in the day.
They still are to a lot of us dinosaurs. thumbs
