360/408 magnum edelbrock heads, what head gaskets? #243192
03/04/09 07:21 PM
03/04/09 07:21 PM
Im putting my upper end together for my 408 next week if time allows. I have the 8553 Felpro head gaskets already, but is there a better or more recomended gasket for this particular application?
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: ] #243193
03/04/09 08:45 PM
03/04/09 08:45 PM
PA
moparacer Offline
moparacer  Offline
PA
What compression? I always used the fel pro 1008's on my small blocks....
Save the 8553's for somethingt else....
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: moparacer] #243194
03/04/09 08:48 PM
03/04/09 08:48 PM
hi
sharpie Offline
Moparts Linguist
sharpie  Offline
Moparts Linguist
hi
Edelbrock suggests their gaskets
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: sharpie] #243195
03/04/09 11:11 PM
03/04/09 11:11 PM
It is a 10.2:1 motor. I have looked into the flatout gaskets that hughes sells, they seem a little pricey, but if a felpro 1008 works well, I will probably check those out.
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: ] #243196
03/04/09 11:36 PM
03/04/09 11:36 PM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
I run Cometics on mine
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: a408swinger] #243197
03/04/09 11:40 PM
03/04/09 11:40 PM
What part # is the cometic gasket?
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: a408swinger] #243198
03/04/09 11:41 PM
03/04/09 11:41 PM
MARYLAND
69Cuda340S Offline
69Cuda340S  Offline
MARYLAND
I'd run Felpro 1008 with that setup, that is what I put in my Eddie headed SB stroker.
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: 69Cuda340S] #243199
03/04/09 11:41 PM
03/04/09 11:41 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
X2
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: Stroker Scamp] #243200
03/04/09 11:58 PM
03/04/09 11:58 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
currently got 3 sets of eddy heads being used...
360 10.6 to 1 compression with mopar .028 head gasket....street driven 73 duster with 15k miles on engine..
360 11.5 bracket race engine with ported eddy went 11.00 in vegas with ROL HG31030HT .045 thickness.
360 11.0 bracket engine with ported eddy will race this weekend for 1st time with fel pro 1008.
edelbrock gasket is a fel pro 1008 with their part number on it..just like their head bolts are arp with their part number on them
currently assemblying another 360 with kb107 going to have a set of eddy magnum heads...probably going to use the mopar .028 head gasket again..
i would say if you have good clean surface, alot of head gasket would work....just my opionion
Tony
70 AARCuda Vitamin C
Re: 360/408 magnum edelbrock heads, what head gaskets? [Re: 70AARcuda] #243201
03/05/09 12:39 AM
03/05/09 12:39 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
Thanks I was thinking the eldebrocks were felpro but was unsure.But talked with eldebrock last week.
They are cheaper than the felpro 1008 and also come in a head set so that way you get everything.
Summit
fel pro #1008 2x $35.95= $71.90
edlebrock #7326 1 pair = $63.95
edlebrock head set #7370 =$97.69
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
