360/408 magnum edelbrock heads, what head gaskets?
#243192
03/04/09 07:21 PM
03/04/09 07:21 PM
Im putting my upper end together for my 408 next week if time allows. I have the 8553 Felpro head gaskets already, but is there a better or more recomended gasket for this particular application?
Re: 360/408 magnum edelbrock heads, what head gaskets?
[Re: ]
#243193
03/04/09 08:45 PM
03/04/09 08:45 PM
Posts: 2,497 PA
moparacer
PA
What compression? I always used the fel pro 1008's on my small blocks....
Save the 8553's for somethingt else....
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: sharpie]
#243195
03/04/09 11:11 PM
03/04/09 11:11 PM
It is a 10.2:1 motor. I have looked into the flatout gaskets that hughes sells, they seem a little pricey, but if a felpro 1008 works well, I will probably check those out.
[Re: a408swinger]
#243197
03/04/09 11:40 PM
03/04/09 11:40 PM
What part # is the cometic gasket?
[Re: Stroker Scamp]
#243200
03/04/09 11:58 PM
03/04/09 11:58 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
currently got 3 sets of eddy heads being used...
360 10.6 to 1 compression with mopar .028 head gasket....street driven 73 duster with 15k miles on engine..
360 11.5 bracket race engine with ported eddy went 11.00 in vegas with ROL HG31030HT .045 thickness.
360 11.0 bracket engine with ported eddy will race this weekend for 1st time with fel pro 1008.
edelbrock gasket is a fel pro 1008 with their part number on it..just like their head bolts are arp with their part number on them
currently assemblying another 360 with kb107 going to have a set of eddy magnum heads...probably going to use the mopar .028 head gasket again..
i would say if you have good clean surface, alot of head gasket would work....just my opionion
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
