66-70 B body console lid repair #2428952
01/04/18 04:25 PM
01/04/18 04:25 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
The sheet metal nuts that hold the lid onto the hinge have worn their way into the studs on the lid to the console on my 67 Coronet.
Has anyone ever "thickened" up the studs so the nuts will fit tight on them?
I know they make repro doors, I would prefer to reuse my existing one
Re: 66-70 B body console lid repair [Re: 1970GTX] #2428988
01/04/18 05:29 PM
01/04/18 05:29 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
You can build up the studs. There is a POR product that is a two part product that forms like steel. Very strong.
Or you could buy an undersized pal nut and expand out the threads to create the right size.
Re: 66-70 B body console lid repair [Re: Morty426] #2428993
01/04/18 05:43 PM
01/04/18 05:43 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Re: 66-70 B body console lid repair [Re: 1970GTX] #2429023
01/04/18 06:40 PM
01/04/18 06:40 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
JB Weld, use the marine mix, takes 3-4 hours to set up. but hard as steel
Re: 66-70 B body console lid repair [Re: 1970GTX] #2429096
01/04/18 07:11 PM
01/04/18 07:11 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Originally Posted By 1970GTX
Yes that's the stuff.
If Dayclona says that MARINE JB Weld will work that might be a cheaper and easier way to go.
I would not use regular JB Weld
Re: 66-70 B body console lid repair [Re: Morty426] #2429162
01/04/18 08:31 PM
01/04/18 08:31 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Chris,
The JB weld MARINE epoxy is pretty much on par with the POR-15 putty performance wise/spec wise for finish harness, just that the JB Marine takes a good day or 2 to fully harden, the POR is ready to go in about 12 hrs
Mike
Re: 66-70 B body console lid repair [Re: DAYCLONA] #2429192
01/04/18 10:15 PM
01/04/18 10:15 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Re: 66-70 B body console lid repair [Re: DAYCLONA] #2429274
01/05/18 12:52 AM
01/05/18 12:52 AM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
Chris,
Mike
Thanks Mike up
Re: 66-70 B body console lid repair [Re: 1970GTX] #2429280
01/05/18 01:13 AM
01/05/18 01:13 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Marine Mix JB Weld?
this...you'll see the same PN# as the one you listed (3200 psi tensile), but this is the heavier bodied gray mix, has almost 4000 psi tensile strength
Re: 66-70 B body console lid repair [Re: DAYCLONA] #2429286
01/05/18 01:31 AM
01/05/18 01:31 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Same PN# 8272 that I listed above, but has a 4-6 hr set up time rather than a 20 minute set up, great if you require lots of time for intricate build ups
Re: 66-70 B body console lid repair [Re: 1970GTX] #2429335
01/05/18 04:28 AM
01/05/18 04:28 AM
Greenwood Lake, NY
fuelishnsilly Offline
Greenwood Lake, NY
just curious but what is the big difference between the regular jb weld and the jb weld marine stuff? why couldn't you use the regular stuff on the console lid?
inherited a 69 roadrunner from my grand pop.
Re: 66-70 B body console lid repair [Re: fuelishnsilly] #2429337
01/05/18 04:52 AM
01/05/18 04:52 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I've used both on projects, but IMHO the MARINE version seems to offer a better bond to surfaces
Re: 66-70 B body console lid repair [Re: 1970GTX] #2429339
01/05/18 05:09 AM
01/05/18 05:09 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
Some antiques I was restoring had attachment with similar fitments. I got rid of some of the roughness with emery without sanding down the residual stud. After that I took some thin wall brass tubing from the hobby shop of the "just" right id to fit over the stud and epoxied it on. after all set up I thinned down the od of the tubing just a bit with emery and slightly enlarged the id of the self threading nuts with an awl and ran them on.
Re: 66-70 B body console lid repair [Re: DAYCLONA] #2429403
01/05/18 12:41 PM
01/05/18 12:41 PM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Thanks Mike and Chris! Great info!
Re: 66-70 B body console lid repair [Re: srt] #2430965
01/08/18 11:26 AM
01/08/18 11:26 AM
Cold Spring, NY
1970GTX Offline OP
1970GTX  Offline OP
Cold Spring, NY
Another good idea. Thanks!
Re: 66-70 B body console lid repair [Re: 1970GTX] #2431398
01/09/18 12:46 AM
01/09/18 12:46 AM
Jefferson State
srt Offline
ESYC
srt  Offline
ESYC
Jefferson State
welcome!
necessity is the mother..
