Re: Single Serpentine Belt
[Re: srunge55]
#2428042
01/02/18 11:32 PM
01/02/18 11:32 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
serp belts need a good amount of wrap. I would guess that it would work. Only one way to find out! You could always add idlers if it doesn't work.
[Re: srunge55]
#2428119
01/03/18 02:15 AM
01/03/18 02:15 AM
Posts: 1,807 North Dakota
Azzkikrcuda
North Dakota
I used the water pump and crank pulleys from March. The power steering pulley from a 90's Chevy 350 pick up. Alternator pulley from a 90's Ford V6. I used stock unmodified alternator and PS pump brackets and everything lined up ok. Just made brackets for the idlers, simple and works good.
The only Carbs I care about are under the hood!
[Re: srunge55]
#2428245
01/03/18 12:55 PM
01/03/18 12:55 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
We use a single serpentine on the heads up car. Runs the alternator(yes we have one) vacuum pump all driven by the crank. Motor sees 10,000rpm on pretty much every pass with zero issues.
[Re: srunge55]
#2428368
01/03/18 04:43 PM
01/03/18 04:43 PM
Azzkikrcuda
North Dakota
Stock power steering belt sits out in front of the wp/alternator towards the end of the ps pump shaft. The GM pulley has the belt in towards the pump housing. You just have to switch to the later press on shaft ps pump, mine was off a 77 Aspen. If you are using the stock mopar alternator you can get that pulley from March also. March crank pulley 10301, Water pump pulley 10312, Stock mopar alternator pulley 214
[Re: srunge55]
#2428387
01/03/18 05:40 PM
01/03/18 05:40 PM
Posts: 1,890 Spahn Ranch
RMCHRGR
Spahn Ranch
Excuse the crummy pic but here's mine. No tensioner, it's installed like a regular v belt. No issues. It used to drive the water pump before I got an electric one.
'71 Duster '17 Ram 1500
