Single Serpentine Belt #2428028
01/02/18 10:52 PM
01/02/18 10:52 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Do you think this would work? On a big block I was thinking of a single triangulated serpentine belt to run my alternator, power steering pump and crank. I will have an electric water pump so no pulley to run. If I can modify the power steering brackets to line the pump up with the crank and alternator pulleys I think it might work. I would use the stock tensioning method on the alternator (or turnbuckle style). Has anyone done this or am I crazy?
Thanks,
Steve
Re: Single Serpentine Belt [Re: srunge55] #2428042
01/02/18 11:32 PM
01/02/18 11:32 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
serp belts need a good amount of wrap. I would guess that it would work. Only one way to find out!
You could always add idlers if it doesn't work.
Re: Single Serpentine Belt [Re: srunge55] #2428119
01/03/18 02:15 AM
01/03/18 02:15 AM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
I used the water pump and crank pulleys from March. The power steering pulley from a 90's Chevy 350 pick up. Alternator pulley from a 90's Ford V6. I used stock unmodified alternator and PS pump brackets and everything lined up ok. Just made brackets for the idlers, simple and works good.
The only Carbs I care about are under the hood!
Re: Single Serpentine Belt [Re: srunge55] #2428160
01/03/18 03:57 AM
01/03/18 03:57 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Nicely done, that's given me some ideas. Thanks
Re: Single Serpentine Belt [Re: Azzkikrcuda] #2428162
01/03/18 04:03 AM
01/03/18 04:03 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
I thought the stock PS bracket would have put your PS pulley out in front of the alt and water pump pulleys. Did you have to do anything to get that to line up?
Thanks,
Steve
Re: Single Serpentine Belt [Re: srunge55] #2428204
01/03/18 11:06 AM
01/03/18 11:06 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
It will work just fine. we did one for a customer with an ultra low mount ac compressor and the stock alternator in the stock location.
Superior Design Concepts
2574 Elliott Dr
Troy MI 48083
jerry@sdconcepts.com
www.sdconcepts.com
Facebook page: Superior Design Concepts
www.bcrproducts.com
Re: Single Serpentine Belt [Re: srunge55] #2428245
01/03/18 12:55 PM
01/03/18 12:55 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We use a single serpentine on the heads up car. Runs the alternator(yes we have one) vacuum pump all driven by the crank. Motor sees 10,000rpm on pretty much every pass with zero issues.
Re: Single Serpentine Belt [Re: Al_Alguire] #2428315
01/03/18 03:09 PM
01/03/18 03:09 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I have used a single 6 rib for years on my small block without issue driving alt only. I now have a single on the 511 driving a water pump and alt. No issues at all.
Re: Single Serpentine Belt [Re: srunge55] #2428368
01/03/18 04:43 PM
01/03/18 04:43 PM
North Dakota
Azzkikrcuda Offline
Azzkikrcuda  Offline
North Dakota
Stock power steering belt sits out in front of the wp/alternator towards the end of the ps pump shaft. The GM pulley has the belt in towards the pump housing. You just have to switch to the later press on shaft ps pump, mine was off a 77 Aspen. If you are using the stock mopar alternator you can get that pulley from March also.
March crank pulley 10301, Water pump pulley 10312, Stock mopar alternator pulley 214
Re: Single Serpentine Belt [Re: Azzkikrcuda] #2428381
01/03/18 05:31 PM
01/03/18 05:31 PM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Good info, thanks
Re: Single Serpentine Belt [Re: srunge55] #2428387
01/03/18 05:40 PM
01/03/18 05:40 PM
Spahn Ranch
RMCHRGR Offline
RMCHRGR  Offline
Spahn Ranch
Excuse the crummy pic but here's mine. No tensioner, it's installed like a regular v belt. No issues. It used to drive the water pump before I got an electric one.
'71 Duster
'17 Ram 1500
Re: Single Serpentine Belt [Re: srunge55] #2428657
01/04/18 01:27 AM
01/04/18 01:27 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
we sell just the power steering brackets if you want to run a mini zf pump. and a stock pulley will work on that.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
Re: Single Serpentine Belt [Re: srunge55] #2428701
01/04/18 02:54 AM
01/04/18 02:54 AM
St Louis, MO, USA
srunge55 Offline OP
srunge55  Offline OP
St Louis, MO, USA
Jerry, I checked out your website but didn't see the brackets listed. I guess I need to call for info? I'm not familiar with the ZF pumps but I looked online and they seem to be expensive (if I'm looking at the right part).
Thanks,
Steve
Re: Single Serpentine Belt [Re: srunge55] #2428755
01/04/18 09:29 AM
01/04/18 09:29 AM
Warren, MI
Jerry Offline
Jerry  Offline
Warren, MI
the brackets are something new that haven't hit the site yet.
2574 Elliott Dr
Troy MI 48083
www.sdconcepts.com
www.bcrproducts.com
