#2427731 - 01/02/18 11:31 AM 1969 vs 1970 B Body 4 speed shifter mechanisms
Charger446 Offline
Loc: Northeast MA
I am currently using a 1969 Hurst factory console shifter on my 68 Charger, like the one that would have come on a 69 Charger for example.
Years ago I picked up a 70 console pistol grip handle that I now want to install but I know there are differences in the actual mechanism itself, or actually the lever part so one doesn't smash the dashboard on the 2/3 shift.
I found the correct mechanism but not too excited about dropping 250 on another one, does anyone know if the 69 one can just be modified with a longer lever?
Edited by Charger446 (01/02/18 11:31 AM)
#2427825 - 01/02/18 01:47 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Charger446]
Cuda340 Offline
Loc: Wheatfield, NY
I believe all of the " 3 fingers" that stick down out of the hurst box are longer than the 69 and down boxes. This shortens the throw of all the gears not just the 2-3.
#2427826 - 01/02/18 01:47 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Charger446]
fastmark Offline
Loc: Abilene, Texas
I know the levers on the 70 shifter are longer and the rods are different as well. I think the levers on the tranny are the same Should work if you just get rods.
#2427833 - 01/02/18 01:52 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Charger446]
Cuda340 Offline
Loc: Wheatfield, NY
#2427841 - 01/02/18 02:10 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Cuda340]
Charger446 Offline
Loc: Northeast MA
Thank you! I forgot about Brewers
#2427951 - 01/02/18 05:44 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Charger446]
John_Kunkel Offline
Loc: Rio Linda, CA
A side-by-side comparison, '68-'69 on left, '70 on the right.
I'm supposed to respect my elders, but its getting harder and harder for me to find one now.
#2427994 - 01/02/18 06:54 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: John_Kunkel]
mccannix Offline
Loc: Ontario, Canada
Although the above Hurst Competition Plus 68-69 mechanism will fit the application, this is a correct assembly line 68-69 mechanism which takes the slide in handle and has the correct size finger openings for linkage without using bushings.
Just stating, in case you stumble on to one exact as above and are not sure of application.
#2428090 - 01/02/18 09:51 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: mccannix]
Charger446 Offline
Loc: Northeast MA
Appreciate the photos guys, very helpful.
#2428202 - 01/03/18 08:04 AM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: Charger446]
therocks Offline
Its Lost
Loc: Niles , Ohio
I was going to say factory didnt use Comp Plus after 65.My 65 came withj one.They went from Inland in 66 to just Comp boxes.I have a 71 pistol grip top for my 65 box I change when I pull the OE one.I had to drill it as it was the slip fit type.Supposedly you can drill the Comp box for the stop bolts like the Plus has.Sold the 71 box after I pulled the pistol handle.Rocky
Edited by therocks (01/03/18 08:06 AM)
Chrysler Firepower
#2428234 - 01/03/18 09:24 AM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: John_Kunkel]
rarefish Offline
Loc: New York
The shifter on the left in your photo has the two stop bolts. Factory Hurst shifters used in 1968 and later did not have them, but they could have been added...
#2428348 - 01/03/18 12:56 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: rarefish]
John_Kunkel Offline
Loc: Rio Linda, CA
Jeez guys, the pic was for a comparison of lever lengths. rolleyes
#2428362 - 01/03/18 01:34 PM Re: 1969 vs 1970 B Body 4 speed shifter mechanisms [Re: John_Kunkel]
mccannix Offline
No problem here John...I always value your input and knowledge.
I was just trying to help the OP steer clear of dropping $250.00 which he had a chance to, on a Comp Plus mech that a seller may be trying to claim was factory assembly line correct.
25,535 Registered Members
194,025 Topics
Magnum art
by bigdad
10/19/18 12:16 PM
Politics!
by tboomer
10/19/18 12:11 PM
727 won’t kickdown
by f2502011
10/19/18 12:01 PM
Part Number look Up Question
by 44D6PAKCUDA
10/19/18 10:07 AM
