#2426647 - 12/31/17 05:10 PM 2008 5.7 any good?
11secaarcuda Offline
Loc: WASHINGTON, PA
found a 2008 5.7 for a good price. is it good for a performance build or should I look for a newer model year?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
#2426712 - 12/31/17 06:50 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
GoodysGotaCuda Online   penguin-006
5.7L Hemi, 6spd
Loc: Texas
What are you looking to do with it?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
1969 Dodge Dart Custom Sedan - Grandma Edition - 318/904
2016 Subaru WRX - E30 Tune ~320whp
#2426723 - 12/31/17 07:05 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
WO23Coronet Offline
Loc: Canada
How much is it and what are you looking to do? Factory intake or aftermarket? Stroker? If you’re doing a build, Eagle heads can be added, although early 5.7 heads can flow a ton of air as well, they’re just at the bottom rung (although the bottom rung is pretty high in this case, they flow 265+ untouched) of the factory offerings
#2426920 - 12/31/17 11:56 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
71yelladustr Offline
Loc: Missouri U.S.A.
Go for it. The 03-08 5.7 offers the most potential vs. cost other gen III engines IMHO. It is also the most versatile especially if you are thinking of using a carb.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
#2426975 - 01/01/18 06:47 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
ric3xrt Offline
Loc: Trumbauersville PA
There are Crap, Junk, I'll do you a favor I'll drive from my end of PA to yours to pay you what you paid.... wave
Seriously, depending on what you want to do, it's your best starting point.
350-425 Hp is not that far away from a stock long block, a good crank,rods and pistons, 450 to about 550 is achievable with a set of worked stock heads. Eagle heads can get you to 600 NA.
#2427453 - 01/01/18 07:57 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
gremlinsteve Offline
Loc: houston texas
A early 5.7 based 392 stroker would be killer
So easy to make power
if You Like Gremlinsteve. Gremlinsteve Likes You.
#2427576 - 01/02/18 12:00 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
Silver70 Online   tonguue
Loc: Rust Belt, SW PA
I find the 09 up for half the price or even less than that vs the early ones. I've had 3 03-08s, all ended up with spun rod bearings. I'll never install another 03-08 without pulling and checking every bearing no matter what the mileage or how clean it looks.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2427618 - 01/02/18 05:59 AM Re: 2008 5.7 any good? [Re: Silver70]
Loc: WASHINGTON, PA
What all is required to swap into a 67 Dart that currently has a 340 4 speed in it?
2011 Hemi Durango
#2427622 - 01/02/18 06:49 AM Re: 2008 5.7 any good? [Re: Silver70]
ric3xrt Offline
I won't install one with out removing everything factory, its like a 9 inch ford rear, once you remove all the factory stuff , you can really beat on them.
#2427623 - 01/02/18 06:58 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
ric3xrt Offline
Motor mounts(http://www.engine-swaps.com/Pages/ProductsType/57.61Hemi.html#head6 )or front plate) Headers(TTI) and some form of ignition system, the MSD Hemi-6 seams to be a good one to start with for NA. if your going Fuel injection Megasquirt, or Holley EFI
Your Bell-housing will work , you just need a G3 hemi specific Flywheel.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
25,541 Registered Members
194,182 Topics
Wood trailer floor...............
by Michael
10/23/18 08:21 PM
Ram Bedside Wheelwell Rust - Here's Why:
by Sunroofcuda
10/23/18 07:49 PM
Engine Oil Preheater
by Dads426
10/23/18 07:46 PM
f11 polish
by btomasko
10/23/18 07:27 PM
