2008 5.7 any good? #2426647
12/31/17 08:10 PM
12/31/17 08:10 PM
WASHINGTON, PA
11secaarcuda Offline OP
WASHINGTON, PA
found a 2008 5.7 for a good price. is it good for a performance build or should I look for a newer model year?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2426712
12/31/17 09:50 PM
12/31/17 09:50 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
What are you looking to do with it?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2426723
12/31/17 10:05 PM
12/31/17 10:05 PM
Canada
WO23Coronet Offline
WO23Coronet  Offline
Canada
How much is it and what are you looking to do? Factory intake or aftermarket? Stroker? If you’re doing a build, Eagle heads can be added, although early 5.7 heads can flow a ton of air as well, they’re just at the bottom rung (although the bottom rung is pretty high in this case, they flow 265+ untouched) of the factory offerings
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2426920
01/01/18 02:56 AM
01/01/18 02:56 AM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
Go for it. The 03-08 5.7 offers the most potential vs. cost other gen III engines IMHO. It is also the most versatile especially if you are thinking of using a carb.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2426975
01/01/18 09:47 AM
01/01/18 09:47 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
There are Crap, Junk, I'll do you a favor I'll drive from my end of PA to yours to pay you what you paid.... wave
Seriously, depending on what you want to do, it's your best starting point.
350-425 Hp is not that far away from a stock long block, a good crank,rods and pistons, 450 to about 550 is achievable with a set of worked stock heads. Eagle heads can get you to 600 NA.
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2427453
01/01/18 10:57 PM
01/01/18 10:57 PM
houston texas
gremlinsteve Offline
houston texas
A early 5.7 based 392 stroker would be killer
So easy to make power
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2427576
01/02/18 03:00 AM
01/02/18 03:00 AM
Rust Belt, SW PA
Silver70 Offline
Silver70  Offline
Rust Belt, SW PA
I find the 09 up for half the price or even less than that vs the early ones. I've had 3 03-08s, all ended up with spun rod bearings. I'll never install another 03-08 without pulling and checking every bearing no matter what the mileage or how clean it looks.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
Re: 2008 5.7 any good? [Re: Silver70] #2427618
01/02/18 08:59 AM
01/02/18 08:59 AM
WASHINGTON, PA
WASHINGTON, PA
What all is required to swap into a 67 Dart that currently has a 340 4 speed in it?
2011 Hemi Durango
Re: 2008 5.7 any good? [Re: Silver70] #2427622
01/02/18 09:49 AM
01/02/18 09:49 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
I won't install one with out removing everything factory, its like a 9 inch ford rear, once you remove all the factory stuff , you can really beat on them.
Re: 2008 5.7 any good? [Re: 11secaarcuda] #2427623
01/02/18 09:58 AM
01/02/18 09:58 AM
Trumbauersville PA
ric3xrt Offline
ric3xrt  Offline
Trumbauersville PA
Motor mounts(http://www.engine-swaps.com/Pages/ProductsType/57.61Hemi.html#head6 )or front plate) Headers(TTI) and some form of ignition system, the MSD Hemi-6 seams to be a good one to start with for NA. if your going Fuel injection Megasquirt, or Holley EFI
Your Bell-housing will work , you just need a G3 hemi specific Flywheel.
Truth has no agenda, but those with an agenda make their own truth.
Some of us are so open minded they only see their View
