#2426647 - 12/31/17 05:10 PM 2008 5.7 any good?
11secaarcuda Offline
Loc: WASHINGTON, PA
found a 2008 5.7 for a good price. is it good for a performance build or should I look for a newer model year?
67 Dart GT 340 4 speed
70 AAR Cuda 408 6 barrel
96 Indy Ram original owner
2011 Hemi Durango
#2426712 - 12/31/17 06:50 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
GoodysGotaCuda Offline
5.7L Hemi, 6spd
Loc: Texas
What are you looking to do with it?
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - Build page -> https://www.facebook.com/GoodysGotaHemi<-
1976 Dodge Warlock - "Her Truck" - 360/727 2wd
2016 BMW X1
2016 Subaru WRX
#2426723 - 12/31/17 07:05 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
WO23Coronet Offline
Loc: Canada
How much is it and what are you looking to do? Factory intake or aftermarket? Stroker? If you’re doing a build, Eagle heads can be added, although early 5.7 heads can flow a ton of air as well, they’re just at the bottom rung (although the bottom rung is pretty high in this case, they flow 265+ untouched) of the factory offerings
#2426920 - 12/31/17 11:56 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
71yelladustr Offline
Loc: Missouri U.S.A.
Go for it. The 03-08 5.7 offers the most potential vs. cost other gen III engines IMHO. It is also the most versatile especially if you are thinking of using a carb.
71 duster 452" 906 heads by KG, E-85 727 Dana 60
#2426975 - 01/01/18 06:47 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
ric3xrt Offline
Loc: Sellersville Pa
There are Crap, Junk, I'll do you a favor I'll drive from my end of PA to yours to pay you what you paid.... wave
Seriously, depending on what you want to do, it's your best starting point.
350-425 Hp is not that far away from a stock long block, a good crank,rods and pistons, 450 to about 550 is achievable with a set of worked stock heads. Eagle heads can get you to 600 NA.
#2427453 - 01/01/18 07:57 PM Re: 2008 5.7 any good? [Re: 11secaarcuda]
gremlinsteve Offline
Loc: houston texas
A early 5.7 based 392 stroker would be killer
So easy to make power
if You Like Gremlinsteve. Gremlinsteve Likes You.
#2427576 - 01/02/18 12:00 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
Silver70 Offline
Loc: Rust Belt, SW PA
I find the 09 up for half the price or even less than that vs the early ones. I've had 3 03-08s, all ended up with spun rod bearings. I'll never install another 03-08 without pulling and checking every bearing no matter what the mileage or how clean it looks.
68 Road Runner, 69 Belvedere, 71 Challenger Vert
340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z
99 Trans Am, 66 GTO, 06 Magnum RT AWD
#2427618 - 01/02/18 05:59 AM Re: 2008 5.7 any good? [Re: Silver70]
Loc: WASHINGTON, PA
What all is required to swap into a 67 Dart that currently has a 340 4 speed in it?
2011 Hemi Durango
#2427622 - 01/02/18 06:49 AM Re: 2008 5.7 any good? [Re: Silver70]
ric3xrt Offline
I won't install one with out removing everything factory, its like a 9 inch ford rear, once you remove all the factory stuff , you can really beat on them.
#2427623 - 01/02/18 06:58 AM Re: 2008 5.7 any good? [Re: 11secaarcuda]
ric3xrt Offline
Motor mounts(http://www.engine-swaps.com/Pages/ProductsType/57.61Hemi.html#head6 )or front plate) Headers(TTI) and some form of ignition system, the MSD Hemi-6 seams to be a good one to start with for NA. if your going Fuel injection Megasquirt, or Holley EFI
Your Bell-housing will work , you just need a G3 hemi specific Flywheel.
Truth has no agenda, but those with an agenda don't always acknowledge truth
2003 Ram st
2004 Rumble Bee
2005 Ram GTX
Any info on these trucks is greatly appreciated
2005 Ram 1500 (drag truck in building
2014 1500 tradesman(shhhh, it's hiding a 7.0 short block under those eagle heads.
25,066 Registered Members
185,553 Topics
Drag racing Stock 318 upgrade and times?
by Dodger73
01/16/18 02:45 AM
Help How to load trailer with non-run Dart GTS by self???
by A12
01/16/18 02:37 AM
'73-'74 spool engine mounts
by 340clone
01/16/18 12:52 AM
Stock torque converter for 727 big block?
by 340clone
01/16/18 12:44 AM
