2008 5.7 any good?
#2426647
12/31/17 08:10 PM
12/31/17 08:10 PM
Posts: 2,403 WASHINGTON, PA
11secaarcuda
WASHINGTON, PA
found a 2008 5.7 for a good price. is it good for a performance build or should I look for a newer model year?
67 Dart GT 340 4 speed 70 AAR Cuda 408 6 barrel 96 Indy Ram original owner 2011 Hemi Durango
Re: 2008 5.7 any good?
[Re: 11secaarcuda]
#2426920
01/01/18 02:56 AM
01/01/18 02:56 AM
Posts: 1,035 Missouri U.S.A.
71yelladustr
Missouri U.S.A.
Go for it. The 03-08 5.7 offers the most potential vs. cost other gen III engines IMHO. It is also the most versatile especially if you are thinking of using a carb.
392 gen III hemi on E-85 727 trans Dana 60 10.02@134
[Re: 11secaarcuda]
#2426975
01/01/18 09:47 AM
01/01/18 09:47 AM
Posts: 1,400 Trumbauersville PA
ric3xrt
Trumbauersville PA
found a 2008 5.7 for a good price. is it good for a performance build or should I look for a newer model year? There are Crap, Junk, I'll do you a favor I'll drive from my end of PA to yours to pay you what you paid.... Seriously, depending on what you want to do, it's your best starting point. 350-425 Hp is not that far away from a stock long block, a good crank,rods and pistons, 450 to about 550 is achievable with a set of worked stock heads. Eagle heads can get you to 600 NA.
[Re: 11secaarcuda]
#2427453
01/01/18 10:57 PM
01/01/18 10:57 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
A early 5.7 based 392 stroker would be killer So easy to make power
if You Like Gremlinsteve. Gremlinsteve Likes You.
[Re: 11secaarcuda]
#2427576
01/02/18 03:00 AM
01/02/18 03:00 AM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I find the 09 up for half the price or even less than that vs the early ones. I've had 3 03-08s, all ended up with spun rod bearings. I'll never install another 03-08 without pulling and checking every bearing no matter what the mileage or how clean it looks.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: Silver70]
#2427618
01/02/18 08:59 AM
01/02/18 08:59 AM
11secaarcuda
WASHINGTON, PA
What all is required to swap into a 67 Dart that currently has a 340 4 speed in it?
[Re: Silver70]
#2427622
01/02/18 09:49 AM
01/02/18 09:49 AM
ric3xrt
Trumbauersville PA
I find the 09 up for half the price or even less than that vs the early ones. I've had 3 03-08s, all ended up with spun rod bearings. I'll never install another 03-08 without pulling and checking every bearing no matter what the mileage or how clean it looks. I won't install one with out removing everything factory, its like a 9 inch ford rear, once you remove all the factory stuff , you can really beat on them.
[Re: 11secaarcuda]
#2427623
01/02/18 09:58 AM
01/02/18 09:58 AM
ric3xrt
Trumbauersville PA
What all is required to swap into a 67 Dart that currently has a 340 4 speed in it? Motor mounts( http://www.engine-swaps.com/Pages/ProductsType/57.61Hemi.html#head6 )or front plate) Headers(TTI) and some form of ignition system, the MSD Hemi-6 seams to be a good one to start with for NA. if your going Fuel injection Megasquirt, or Holley EFI Your Bell-housing will work , you just need a G3 hemi specific Flywheel.
Truth has no agenda, but those with an agenda make their own truth. Some of us are so open minded they only see their View
