03 1500 9 1/4 rear end swap issue
#2425105
12/28/17 10:49 PM
12/28/17 10:49 PM
Posts: 1,607 Pgh, PA
Bull1tt
Pgh, PA
My original Sure-grip 9 1/4 rear end blew up a while back, so I swapped the rear end from another 03 truck I had. Both trucks are two-wheel drive. Of course this one had a horrible pinion whine at 45-55 mph. I’ve run it for over a year, but it developed a vibration and the howl went away. I bought another rear from a 4wd ‘03, and the plug for the ABS tone ring is different. Luckily, the wires were cut, so I wired it to existing two wires. Colors were different, so I did the guess. Now my dash ‘Brake’ and ABS lights are on. Switched wires around to no help. Any ideas?
Re: 03 1500 9 1/4 rear end swap issue
[Re: Bull1tt]
#2425201
12/29/17 01:17 AM
12/29/17 01:17 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Buy another one or
Put a piece of electrical tape over the offending light.
[Re: Bull1tt]
#2433167
01/12/18 01:18 AM
01/12/18 01:18 AM
Posts: 32,970 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Disconnect the battery and let it clear the codes. Does the rear axle assembly have abs sensors on it?
[Re: geo.]
#2434312
01/14/18 10:51 AM
01/14/18 10:51 AM
Bull1tt
Pgh, PA
I don't know the answer to this, but are all the tone rings the same? Is it worth taking off the cover and counting the teeth? I don’t know that either, but they did change the speed sensor style in 05/06. That makes me wonder. I had the cover off initially, to check condition, and I put $60 worth of Royal Purple gear oil in it. Cover stays on for now.
[Re: stumpy]
#2434679
01/14/18 11:00 PM
01/14/18 11:00 PM
Posts: 727 Cleveland Ohio
sportfury70
Cleveland Ohio
I believe you need to touch battery cables ends together for approx 15 seconds with headlights on to deplete any memory in computer. I've had to do this with my 07 minivan & also my 2011 ram 1500 to completely clear code.
[Re: Bull1tt]
#2434869
01/15/18 06:19 AM
01/15/18 06:19 AM
Posts: 10,153 A Red State
SNK-EYZ
A Red State
When you connected the rear axle speed sensor wires back together how did you do it?
The correct way per Dodge is to solder them and used heat shrink tubing.
With the low voltage that the sensors use crimp connectors could be an issue.
[Re: sportfury70]
#2435414
01/16/18 02:15 AM
01/16/18 02:15 AM
Bull1tt
Pgh, PA
I believe you need to touch battery cables ends together for approx 15 seconds with headlights on to deplete any memory in computer. I've had to do this with my 07 minivan & also my 2011 ram 1500 to completely clear code. I’ve never heard that before...
[Re: SNK-EYZ]
#2435416
01/16/18 02:16 AM
01/16/18 02:16 AM
Bull1tt
Pgh, PA
With the low voltage that the sensors use crimp connectors could be an issue. Of course I used crimp style connectors...
[Re: Bull1tt]
#2435580
01/16/18 12:56 PM
01/16/18 12:56 PM
sportfury70
Cleveland Ohio
Ok. I hadn't either. What's it hurt to try it? Worked for me. Makes no difference to me. This is why I generally don't reply.
[Re: sportfury70]
#2437151
01/18/18 10:49 PM
01/18/18 10:49 PM
Bull1tt
Pgh, PA
Ok. I hadn't either. What's it hurt to try it? Worked for me. Makes no difference to me. This is why I generally don't reply. Well, I only was saying I’ve never heard that before. Nothing more... and prob will try, can’t hurt!
