odd crank balance question #2424037
12/26/17 07:20 PM
12/26/17 07:20 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Hi,
Ive a semi rare crank I need to get balanced, its got three slugs in it from prior use of old heavy rods and pistons.
Its gonna need alot of weight removed.
Can they drill on the opposing sides of the mallory or should I grind the welds down and press out the slugs before I take it in.
Two are pressed,welded from the sides, one is from the top.
Thanks.
Re: odd crank balance question [Re: Porter67] #2424072
12/26/17 08:14 PM
12/26/17 08:14 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Take it to the shop doing the balancing and let them tell you what needs to be done.
Re: odd crank balance question [Re: GODSCOUNTRY340] #2424078
12/26/17 08:29 PM
12/26/17 08:29 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
There you go.
Don't be the exception.
Re: odd crank balance question [Re: Porter67] #2424114
12/26/17 09:59 PM
12/26/17 09:59 PM
You can weigh the pistons/pins/rings/locks (if used) on a HF $9.95 digital scale & with a bit of doing, level the rod so you can weigh each end & then figure your bobweight yourself which will cut your balancing bill almost on half. Holler if you want to go further.
Re: odd crank balance question [Re: Porter67] #2424132
12/26/17 10:23 PM
12/26/17 10:23 PM
P
Porter67 Offline OP
Porter67  Offline OP
P
Thanks, I know I should have them spin it, it just blows its a half days drive there and back.
I know how to get the weights Robert, thanks though.
Its just another cheater motor but in a subtle way, they would have to pull the heads to figure it out more then not.
I want to nut. balance it and ive got the old rods,slugs but it had a 340 cast crank balancer on it (still a steel crank) and im not sure how much weight that is or id compare old vs this new weight.
Re: odd crank balance question [Re: GODSCOUNTRY340] #2424370
12/27/17 02:01 PM
12/27/17 02:01 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Having been down the road with Mallory before, this is the best advice.
