Re: odd crank balance question
[Re: GODSCOUNTRY340]
#2424078
12/26/17 08:29 PM
12/26/17 08:29 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Take it to the shop doing the balancing and let them tell you what needs to be done. There you go.
[Re: Porter67]
#2424114
12/26/17 09:59 PM
12/26/17 09:59 PM
RapidRobert
You can weigh the pistons/pins/rings/locks (if used) on a HF $9.95 digital scale & with a bit of doing, level the rod so you can weigh each end & then figure your bobweight yourself which will cut your balancing bill almost on half. Holler if you want to go further.
#2424370
12/27/17 02:01 PM
12/27/17 02:01 PM
Posts: 10,731 North Dakota
6PakBee
North Dakota
Take it to the shop doing the balancing and let them tell you what needs to be done. Having been down the road with Mallory before, this is the best advice.
