small block headers question
#2423909
12/26/17 02:39 PM
12/26/17 02:39 PM
Posts: 12,011 Finally a HUSKER again
Moparnut426
If you guys had to choose between Tubular Automotive and TTI 1-7/8 headers for a street car that ill take to the track every once in a while, what rout would ya go?
Used ceramic coated Tubular auto slip tube headers in really good shape, but Ill have to run adapters,
Bite the bullet and go with 1 7/8 TTI headers???
difference is around 480 bucks if I go the TTI way
Asking because Ive had bad luck in the past with adapters.
Also know nothing about the Tubular auto stuff. I did call the company and they are really cool and gave me good info, but I didn't ask him how his compare to TTI that's not a fair question to ask a guy abut a competitor.
Kasey
Re: small block headers question
[Re: Moparnut426]
#2423926
12/26/17 03:21 PM
12/26/17 03:21 PM
Posts: 11,719 Portage,michigan
B3422W5
Portage,michigan
Had a buddy who had the tubular auto 1 7/8 headers on a 408 in a 72 Demon. They didnt fit too bad. If its the ones i am thinking, one tube on the driver side slid out( slip fit)
69 Dart GTS A4 Silver All steel, flat factory hood, 3360race weight 418 BPE factory replacement headed stroker, 565 lift solid cam Best so far, 10.40 @127 1/4 1.41 best 60 foot 6.60 at 103.90 1/8
[Re: Moparnut426]
#2423944
12/26/17 04:31 PM
12/26/17 04:31 PM
Posts: 4,988 new jersey usa
11secdart
new jersey usa
I have ran Tubular Automotive headers for years, bought a used set, a new set years ago and am getting ready to buy a new set. I was thinking about the TTIs but heard fit isn't the greatest and they are just to expensive. With the Tubular Automotive headers I have plates for W2 heads and regular heads like an X or J head etc. Mine are 1 7/8 with a 3 1/2 collector
[Re: Moparnut426]
#2423957
12/26/17 05:09 PM
12/26/17 05:09 PM
B3422W5
Portage,michigan
Hey guys, anybody note how high up the collectors are underneath on the TA ones. Is there good ground clearance.
[Re: B3422W5]
#2423961
12/26/17 05:17 PM
12/26/17 05:17 PM
11secdart
new jersey usa
Yes mine have the tabs to bolt the tubes together, mine are just plain worn out from being apart so many times for engine swaps etc.
[Re: 6bblRoadrunner]
#2424026
12/26/17 06:51 PM
12/26/17 06:51 PM
B3422W5
Portage,michigan
B3442W5... I’m out of town right now so I can’t give you any measurements. I’ll be back the end of the week and will post then. Cool. Just want to be able to hook bullets up to them and keep them tight to the undercarriage.
[Re: B3422W5]
#2424036
12/26/17 07:19 PM
12/26/17 07:19 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why no love for the 1 7/8 Hedmen headers?
[Re: pittsburghracer]
#2424044
12/26/17 07:33 PM
12/26/17 07:33 PM
Posts: 4,457 Washington
madscientist
Washington
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes.
[Re: madscientist]
#2424060
12/26/17 08:00 PM
12/26/17 08:00 PM
Posts: 20,185 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes. I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL
[Re: Moparnut426]
#2424065
12/26/17 08:02 PM
12/26/17 08:02 PM
Posts: 1,927 Seaford, Va
Kindafast
Seaford, Va
I can't do a comparison on the headers but I do know my stepped TTI Headers fit my car with no problems. Mine have the slip on pipe for for number 7 Cyl but I have never needed to take it off during standard engine and transmission services. They slide right in from the bottom and bolt right up. If and when my wear out I will get the exact same headers again. My 2cents
6.50 @105.26
#2424070
12/26/17 08:12 PM
12/26/17 08:12 PM
Moparnut426
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes. I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL My Supercomps are for a full bodied car that fit with tortion bars, not a fender well header
[Re: Moparnut426]
#2424074
12/26/17 08:17 PM
12/26/17 08:17 PM
Posts: 8,028 Tulsa OK
Bad340fish
Tulsa OK
I have TTI 1 7/8 with W2s in an A body. They fit great, tight but great. They mention in the instructions that you need to jack the car up to install. What they do not mention is that you have to jack the car up really really really high lol.
68 Barracuda Formula S 340
[Re: J_BODY]
#2429255
01/05/18 12:00 AM
01/05/18 12:00 AM
Posts: 3,517 pacific northwest
Stroker Scamp
pacific northwest
I had the TTI step headers in the Scamp and they fit real well. I swapped those out for the Hedman 1 7/8, these come in pieces and one tube goes thru each fire wall/ Swapped the TTI's into the Duster and and a real goof it there too
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip 73 Duster 340 street strip 12.79 @ 105
[Re: Moparnut426]
#2429300
01/05/18 02:04 AM
01/05/18 02:04 AM
Posts: 16,479 Canada
CrAzYMoPaRGuY
Canada
the supercomps hit EVERYTHING!!!
I have never heard this. I have Hooker SuperComps but they are only 1 3/4 primaries. Should be easy fit if they fit like the ones I have seen....? Are there bigger SuperComps than 5115s?
CrAzYMoPaRGuY
[Re: CrAzYMoPaRGuY]
#2429425
01/05/18 01:37 PM
01/05/18 01:37 PM
Posts: 3,521 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
the supercomps hit EVERYTHING!!! I have never heard this. I have Hooker SuperComps but they are only 1 3/4 primaries. Should be easy fit if they fit like the ones I have seen....? Are there bigger SuperComps than 5115s? We had 2 inch SuperComps for stock and W2 heads. All headers are a PIA but I these are at the bottom of my list for fitment. Even after you do everything needed to get them to fit they still were very difficult to get on. The last time I took them off I swore it would be the last time. Bill
#2429435
01/05/18 02:10 PM
01/05/18 02:10 PM
Posts: 11,684 W. Kentucky
justinp61
W. Kentucky
Why no love for the 1 7/8 Hedmen headers? I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes. I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL I have the Hedmans and like them a lot. The holes in the fenderwell are no big deal and can easily be done so they don't look like a hack job. The Milodon pans do take some work though, I have two that I have cut the sides out and welded new scaloped pieces in to clear the tubes. I bought Hedmans because Ryan johnson told me that on an engine like my 408 they made more power on a dyno than TTI's, IIRC 30-35 hp.
