small block headers question #2423909
12/26/17 02:39 PM
12/26/17 02:39 PM
Finally a HUSKER again
Moparnut426 Offline OP
If you guys had to choose between Tubular Automotive and TTI 1-7/8 headers for a street car that ill take to the track every once in a while, what rout would ya go?
Used ceramic coated Tubular auto slip tube headers in really good shape, but Ill have to run adapters,
Bite the bullet and go with 1 7/8 TTI headers???
difference is around 480 bucks if I go the TTI way
Asking because Ive had bad luck in the past with adapters.
Also know nothing about the Tubular auto stuff. I did call the company and they are really cool and gave me good info, but I didn't ask him how his compare to TTI that's not a fair question to ask a guy abut a competitor.
Kasey
Re: small block headers question [Re: Moparnut426] #2423924
12/26/17 03:17 PM
12/26/17 03:17 PM
Earth
Rob C Offline
Rob C  Offline
Earth
I have seen the Auto-tube site before and it only seems to be that one page. I don’t know anybody that has there product. The site, er, page has a huge lack of information. So I can not compare! Is there header scratch built? Do you need - Can/will the do a steppes header? Lots of questions!
I have the tti 1-5/8 - 1-3/4 on my 360 in an A body. While the fit was excellent, it wasn’t perfect. It did require a ding at the manual steering box. I also grounded down the head of the bolt with hope it would clear. Close. No dice. The ding needed was very minor.
Re: small block headers question [Re: Moparnut426] #2423926
12/26/17 03:21 PM
12/26/17 03:21 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Had a buddy who had the tubular auto 1 7/8 headers on a 408 in a 72 Demon. They didnt fit too bad.
If its the ones i am thinking, one tube on the driver side slid out( slip fit)
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: small block headers question [Re: Moparnut426] #2423933
12/26/17 03:51 PM
12/26/17 03:51 PM
These things are darn near 100% slip fit centers are slip tube, slip collector, etc etc...
Kasey
Re: small block headers question [Re: Moparnut426] #2423944
12/26/17 04:31 PM
12/26/17 04:31 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
I have ran Tubular Automotive headers for years, bought a used set, a new set years ago and am getting ready to buy a new set. I was thinking about the TTIs but heard fit isn't the greatest and they are just to expensive. With the Tubular Automotive headers I have plates for W2 heads and regular heads like an X or J head etc. Mine are 1 7/8 with a 3 1/2 collector
68 Dart 410 / 904
92 D150 original owner
21 Ram 1500 Quad Cab, Big Horn , Hemi ,4x4
23 Audi Q5
16 Honda HRV
Re: small block headers question [Re: Moparnut426] #2423955
12/26/17 05:06 PM
12/26/17 05:06 PM
South Lyon, Michigan
6bblRoadrunner Offline
Having no experience with TTI headers I can’t comment on them. I do have a set of T/A headers on my ‘71 Demon (W2’s with 4spd). I had an issue with #3&5 hitting the steering shaft when I first bought them...probably about 10 years ago. They fixed the issue without any problem. They are slip fit as mentioned and have tabs to bolt the tubes together. I assume yours do as well. As with any header I’ve ever installed, you will probably have to do some “clearancing” to get to fit your car. Would I use them again...definitely.
Re: small block headers question [Re: Moparnut426] #2423957
12/26/17 05:09 PM
12/26/17 05:09 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Hey guys, anybody note how high up the collectors are underneath on the TA ones. Is there good ground clearance.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: small block headers question [Re: B3422W5] #2423961
12/26/17 05:17 PM
12/26/17 05:17 PM
new jersey usa
11secdart Offline
11secdart  Offline
new jersey usa
Yes mine have the tabs to bolt the tubes together, mine are just plain worn out from being apart so
many times for engine swaps etc.
68 Dart 410 / 904
23 Audi Q5
16 Honda HRV
Re: small block headers question [Re: B3422W5] #2423971
12/26/17 05:32 PM
12/26/17 05:32 PM
B3442W5... I’m out of town right now so I can’t give you any measurements. I’ll be back the end of the week and will post then.
Re: small block headers question [Re: Moparnut426] #2424005
12/26/17 06:15 PM
12/26/17 06:15 PM
I hate having to use the adapter flanges, have never seen a gain other than leaks, are these ok? or do they leak like crazy my Indybrocks use standary LA pattern
Re: small block headers question [Re: 6bblRoadrunner] #2424026
12/26/17 06:51 PM
12/26/17 06:51 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Cool. Just want to be able to hook bullets up to them and keep them tight to the undercarriage.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: small block headers question [Re: B3422W5] #2424036
12/26/17 07:19 PM
12/26/17 07:19 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
Why no love for the 1 7/8 Hedmen headers?
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: small block headers question [Re: Moparnut426] #2424042
12/26/17 07:31 PM
12/26/17 07:31 PM
the supercomps hit EVERYTHING!!!
Re: small block headers question [Re: pittsburghracer] #2424044
12/26/17 07:33 PM
12/26/17 07:33 PM
Washington
madscientist Offline
Washington
I think those are the headers you have to cut a hole in the fender well for the 7-8 tubes.
Re: small block headers question [Re: madscientist] #2424060
12/26/17 08:00 PM
12/26/17 08:00 PM
PA.
"Little"John
"Little"John
PA.
I have a saw and torches they can borrow. And a 4 pound hammer if they use the Milidon oil pan. LOL
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: small block headers question [Re: Moparnut426] #2424065
12/26/17 08:02 PM
12/26/17 08:02 PM
Seaford, Va
Kindafast Offline
Kindafast  Offline
Seaford, Va
I can't do a comparison on the headers but I do know my stepped TTI Headers fit my car with no problems. Mine have the slip on pipe for for number 7 Cyl but I have never needed to take it off during standard engine and transmission services. They slide right in from the bottom and bolt right up. If and when my wear out I will get the exact same headers again. My 2cents
6.50 @105.26
Re: small block headers question [Re: pittsburghracer] #2424070
12/26/17 08:12 PM
12/26/17 08:12 PM
My Supercomps are for a full bodied car that fit with tortion bars, not a fender well header
Re: small block headers question [Re: Moparnut426] #2424074
12/26/17 08:17 PM
12/26/17 08:17 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I have TTI 1 7/8 with W2s in an A body. They fit great, tight but great. They mention in the instructions that you need to jack the car up to install. What they do not mention is that you have to jack the car up really really really high lol.
68 Barracuda Formula S 340
Re: small block headers question [Re: B3422W5] #2427090
01/01/18 02:37 PM
01/01/18 02:37 PM
B3442W5....I measured the lowest point of the collector to the subframe and it looks to be about 3 1/2” (collector below the subframe) on the drivers side and about 4 1/2” on the passenger side.
Re: small block headers question [Re: Moparnut426] #2429222
01/04/18 11:02 PM
01/04/18 11:02 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Our W5 TTI headers were probably the BEST out of the box headers we've ever had... bar none! (some results may vary). We've also had the Hedman Hustlers for our iron head 360 (see Pitts comment about the Milodon oil pan, had to change two tubes for fitment).
Currently run custom set of headers patterned after our Hustlers. One of the better $1400 investments on the car (W8.... not ordering those from Jegs/Summit).
