Automatic Trans Holding Fixture
#2423167
12/24/17 05:20 PM
12/24/17 05:20 PM
Posts: 8,068 Tulsa OK
Bad340fish
Tulsa OK
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input.
68 Barracuda Formula S 340
Re: Automatic Trans Holding Fixture
[Re: Bad340fish]
#2423216
12/24/17 07:04 PM
12/24/17 07:04 PM
Posts: 26,384 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I keep it simple, it's served me for 40+ years.
[Re: qwkmopardan]
#2423289
12/24/17 09:27 PM
12/24/17 09:27 PM
Posts: 5,995 Anoka County, MN
Leigh
Anoka County, MN
Just use a common 2 wheel dolly. Put bellhousing end up and tailshaft on the floorplate. Use a ratchet strap just above the pan surface at back of bell to hold it to the dolly. Done 100+ this way. 👍 Exactly what I do.
[Re: Bad340fish]
#2423294
12/24/17 09:37 PM
12/24/17 09:37 PM
Bad340fish
Tulsa OK
Some great ideas here thank you. I have been meaning to buy a two wheel dolly anyways, I might try that method. Between selling an engine block and working on a dana 60 project I have had several "dang I wish I had a dolly" moments the last few weeks.
[Re: topside]
#2423326
12/24/17 10:38 PM
12/24/17 10:38 PM
dartman366
Mt. Vernon, Ohio
I had a plate water jetted out with the hole patterns of small block and big block bolt patterns and used an old light weight motor stand and converted it to a tranny stand, works great, I can roll/spin it around in any position.
[Re: Bad340fish]
#2423371
12/25/17 12:52 AM
12/25/17 12:52 AM
Posts: 1,131 Thigh-Gap Junction
New user name, Same old jerk!
Thigh-Gap Junction
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input. I've never used a fixture. Once the tailshaft housing is on, one block to prop that end up and another to keep it from rolling and that's it. On the bench, on the floor, on the tailgate of the pickup, wherever is handy.
[Re: Bad340fish]
#2423387
12/25/17 01:20 AM
12/25/17 01:20 AM
Posts: 10,072 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case.
8.582, 160.18 mph best, 2905 lbs 549, indy 572-13, alky
[Re: gregsdart]
#2423417
12/25/17 03:00 AM
12/25/17 03:00 AM
Posts: 883 Affton MO
qwkmopardan
Affton MO
I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case. That wont work when ears are removed for the CSR shield.
[Re: qwkmopardan]
#2423515
12/25/17 12:48 PM
12/25/17 12:48 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I do all of my trans work at my welding bench and I made up a couple of arms that are welded.. I have a 1/2" hole in the bench so it just bolts to the bench.. very simple.. I've done 5 518s on it so far.. plus I have a tool to compress the OD clutch(about 900* pressure.. I have all the stuff needed for doing the 518s) ![wave wave](/ubbthreads/images/graemlins/custom/wave.gif)
[Re: gregsdart]
#2423522
12/25/17 12:56 PM
12/25/17 12:56 PM
Posts: 693 Dunnellon, FL
longram60
Dunnellon, FL
I use a similar set-up with my engine stand, bur with a C shaped angle iron fixture bolted to the face of the tranny (I'll post a pic when I get home) I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case.
1979 AMC Spirit, NHRA Q/SA
[Re: MoParFish]
#2423678
12/25/17 05:57 PM
12/25/17 05:57 PM
Posts: 9,826 las vegas
70AARcuda
las vegas
Nuttin' fancy here. Hole drilled in edge of bench with a screwdriver dropped thru bell hole. Has worked ok for as many as I mess with but, might make something better next time around. Is the screw driver from Harbor Freight?
Tony
70 AARCuda Vitamin C 71 Dart Swinger 360 10.318 @ 128.22(10-04-14 Bakersfield) 71 Demon 360 10.666 @122.41 (01-29-17 @ Las Vegas) 71 Duster 408 (10.29 @ 127.86 3/16/19 Las Vegas)
[Re: Bad340fish]
#2423823
12/26/17 02:18 AM
12/26/17 02:18 AM
Posts: 12,256 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Blue Point bench mule I bought from Snappy years ago. Has had transmissions and rears on it over the years. It's paid for itself a few times over.
[Re: cudaman1969]
#2423844
12/26/17 10:19 AM
12/26/17 10:19 AM
Posts: 2,416 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
Once it's ready for the guts, Nothing more than a 15? gallon drum (parts cleaner drum) goes together better being vertical. Lol...I thought I was the only one...and I wasn't going to admit it...I don't do them often but I use one for disassembly and the reassembly, I do like the engine stand adapter idea though...right after I finish my engine run in stand I may build one of those...ha...who am I kidding, I can't seem to keep other people's projects out of my shop... ![work work](/ubbthreads/images/graemlins/custom/work.gif)
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: longram60]
#2424198
12/27/17 12:34 AM
12/27/17 12:34 AM
longram60
Dunnellon, FL
I use a similar set-up with my engine stand, bur with a C shaped angle iron fixture bolted to the face of the tranny (I'll post a pic when I get home) I made up some arms to bolt to an engine stand and the tabs on the torqueflite case. Took about an hour to make them out of scrap I had in the shop. Works great. I had some 2x2 tubing and 1/2 x 1 bar stock. I cut four pieces of bar stock to 4 1/2 inch long, drilled a 7/16 hole in one end of each close enough to the end to seat properly on the transmission tabs, and welded them onto the 2x2 x 8 inch long pieces of tubing, with the holes extending out on opposite ends. That allows a lot of adjustability for mounting the trans case. Picture of mine:
[Re: B1MAXX]
#3017943
02/23/22 08:59 AM
02/23/22 08:59 AM
Posts: 4,116 Mo.
racerx
Mo.
Just a couple of gusseted angle brackets, did about a dozen tranny's over 20+ years. I know that some cut the lugs off. I like this setup ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) nice and simple B1maxx was this something you fab. up?
[Re: B1MAXX]
#3017980
02/23/22 11:45 AM
02/23/22 11:45 AM
Posts: 31,189 Oregon
AndyF
With the pivot point so far off center of mass, I would think that could make rotation take a little more effort, or get away from you if your not careful. The pivot is in the center, you just can't see it since it is on the other side.
[Re: Bad340fish]
#3017998
02/23/22 12:41 PM
02/23/22 12:41 PM
Posts: 10,087 MN
JERICOGTX
MN
What is everyone using to hold an automatic transmission while working on them? Trans rebuilding is something I haven't done yet and I think I need to start. Something cheap but safe would be ideal. Also any tool suggestions would be great. Thanks for any input. Hey Clark, here is the proper "Fixture" for a 727. LOL!!!
69 GTX
68 Road Runner
[Re: AndyF]
#3018001
02/23/22 12:43 PM
02/23/22 12:43 PM
Posts: 2,046 Apollo, PA.
B1MAXX
Apollo, PA.
With the pivot point so far off center of mass, I would think that could make rotation take a little more effort, or get away from you if your not careful. The pivot is in the center, you just can't see it since it is on the other side. OK thanks for explaining.
[Re: racerx]
#3018004
02/23/22 12:45 PM
02/23/22 12:45 PM
B1MAXX
Apollo, PA.
Just a couple of gusseted angle brackets, did about a dozen tranny's over 20+ years. I know that some cut the lugs off. I like this setup ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) nice and simple B1maxx was this something you fab. up? Yes just cut up some angle I had around., and some gussets.
[Re: hemi-itis]
#3018005
02/23/22 12:45 PM
02/23/22 12:45 PM
Posts: 8,570 fredericksburg,va
cudaman1969
fredericksburg,va
I'm a simple guy and luckily don't deal with it to often Your bench looks like mine right now, Van overdrive trans. Been thinking of making one to fit on an engine stand sideways, able to spin it and when done set it on the trans jack (they are heavier now a days) Just like BMaxx nice!
[Re: B1MAXX]
#3018600
02/24/22 06:43 PM
02/24/22 06:43 PM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
Just use a common 2 wheel dolly. Put bellhousing end up and tailshaft on the floorplate. Use a ratchet strap just above the pan surface at back of bell to hold it to the dolly. Done 100+ this way. Use a wheelbarrow and you don't even need to mess with the ratchet strap ![[Linked Image]](https://i.imgur.com/rdjGH3L.jpg) I'm not knocking it one bit but the first thing that came into my head was the intro to dueling banjos. You're not the first person to say that. It worked though.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: POZEST]
#3018797
02/25/22 12:32 PM
02/25/22 12:32 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I just use my Blue Point bench mule.
Torqueflites get one leg bolted to the front tab, use a 2 3/4" spacer with a long bolt on the rear tab. If the tabs are gone, I use the bellhousing.
OE Powerglides I use a couple bolts on the pan flange.
[Re: CMcAllister]
#3019532
02/27/22 09:48 PM
02/27/22 09:48 PM
Posts: 562 Kentucky
clovis
Kentucky
Special thanks to B1MAXX, for the extra photos. It enable to me to create one from an engine stand with very little work-$8 worth of the angle iron and I was in business. It works out good as I can drop it onto the middle leg to pre-load the output for checking final clearance. That’s my chief mechanic, at work there with the converter. My dad will turn 80 next birthday, and I still have to fight him to get to the wrenches first.
'75 Plymouth Duster Phase I 451 906/590/2-660 10.75/126 Phase II 451 Stage VI/590/1050 9.82/135 Phase III 383 906/Victor-Pump gas 11.30/119
"For by grace you have been saved through faith. And this is not your own doing; it is the gift of God,"
