Purple shaft cams back ordered forever? #2421197
12/19/17 11:21 PM
12/19/17 11:21 PM
WA
P
pro451bee Offline OP
P
WA
Whats up the forever back order of MOPAR cams?
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421201
12/19/17 11:24 PM
12/19/17 11:24 PM
P
Porter67 Offline
Porter67  Offline
P
Maybe they are rotating the stock or supplier, for the last year summit has dumped at one time or the other almost all the older 90-s kits for $199 shipped, now they seem to be nearly 2x that price.
Or maybe they are just saying F it?
Have you checked ebay for the kit your looking for?
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421204
12/19/17 11:28 PM
12/19/17 11:28 PM
Pa
Hot 340 Offline
Hot 340  Offline
Pa
Chen Huang's berco brok-ren.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421225
12/19/17 11:47 PM
12/19/17 11:47 PM
Fulton County, PA
CMcAllister Online content
Mr. Helpful
CMcAllister  Online Content
Mr. Helpful
Fulton County, PA
Elvis has left the building.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421428
12/20/17 01:46 PM
12/20/17 01:46 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
When the price for a BB 509 cam kit went to $500, I just assumed that was FCA's way of letting everyone know they weren't interested in selling those anymore.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421433
12/20/17 01:56 PM
12/20/17 01:56 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Read along with Todd. Comp Cams Nostalgia Purple PLus. Updated version of the classic with no stupid price and no waiting.....
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421459
12/20/17 03:08 PM
12/20/17 03:08 PM
Guitar Jones Offline
THE SKY IS FALLING! THE SKY IS FALLING! panic laugh2
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421466
12/20/17 03:24 PM
12/20/17 03:24 PM
crabman173
crabman173
Todd is Correct
Nostalgia Purple Plus has nice lobe that makes better power than old Mopar cams and is very easy on the valvetrain
We LOVE'Em and highly suggest you let Todd send you one--You will be very pleased!! The biggest one with some Sidewinder heads in a 440 with compression is a very hot combo
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421481
12/20/17 04:15 PM
12/20/17 04:15 PM
Fulton County, PA
Mr. Helpful
Mr. Helpful
Fulton County, PA
What do you expect from a company that makes pink clown cars?
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421619
12/20/17 10:02 PM
12/20/17 10:02 PM
Step up and buy a good cam, not some low priced piece of junk designed in the 1970s down twocents
Lots of way better choices out there now on camshaft packages scope
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421658
12/20/17 11:17 PM
12/20/17 11:17 PM
WA
P
P
WA
Ya what ever , I want to try a 528 solid in my 451 , those noisy fast lobes are not the best for every one.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421750
12/21/17 04:37 AM
12/21/17 04:37 AM
There are a lot of myths and misinformation spread on and through the internet on web sites like this one, especially about parts which are cheap and parts that are good, seldom will you find a good cheap part work
If you want good performance parts buy good ones, if you want cheap parts that will work okay buy the cheapest ones you can find shruggy whistling
Once you have wasted a bunch of money on cheap parts like cam kits and finally buy a good one and degree it and find out how much better it runs you may learn you like the good parts better work scope
Talk is cheap, performance costs more and is harder to get correct shruggy
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421826
12/21/17 01:13 PM
12/21/17 01:13 PM
So. Burlington, Vt.
So. Burlington, Vt.
I like the Comp XS282S as a great alternative to the MP528 cam in applications where the 2deg tighter lsa won't be a problem.
Of course, you can get something taylored to your specific needs as well.
I have a new BB MP 528 cam I could probably persuaded to part with.
Re: Purple shaft cams back ordered forever? [Re: fast68plymouth] #2421861
12/21/17 02:27 PM
12/21/17 02:27 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
Indeed, if someone has the specs for their favorite purple-shaft thingy they can look in the lobe catalogs of the bigger companies, find similar lobes and put the separation where they think they need it. You could even paint it purple if you want. There's no need to send money to Italy for a camshaft, support your [local] grinder.
twocents
Re: Purple shaft cams back ordered forever? [Re: Cab_Burge] #2421872
12/21/17 03:35 PM
12/21/17 03:35 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
LMAO..........And SO true........... drinking
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421928
12/21/17 05:25 PM
12/21/17 05:25 PM
Big Western Pencilveinya
U
Uncle Barry Offline
Uncle Barry  Offline
U
I have absolutely no idea as to why anyone would want to use one of those things except for being "nostalgic". Soooo many better options out there.
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2421950
12/21/17 06:23 PM
12/21/17 06:23 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I've always loved the solid purpleshaft cams, they've always been a huge bang for the buck. But now that I've seen where the prices have gone on them I would suggest a custom solid or save up for a good roller.
I bought my 590 solid purpleshaft for '$169 with lifters' from Summit Racing, went 9.89 at 136mph in my 451 motor at 3050 pounds.
My current car has the 557 that I bought off Sport440 for 50 bucks, I bought some solid lifters from Summit for less than a 100 bucks.
I drive the car to the track, run 10.60's and drive it home on 93 octane with 3.23 gears.
So I'm not happy to see that the prices have shot up but I'd never say that they are outdated '70's junk(internet myth). If I were to build a car today to run 9.50's I would have no problem with putting that old 590 in the motor. twocents
Re: Purple shaft cams back ordered forever? [Re: pro451bee] #2422015
12/21/17 09:09 PM
12/21/17 09:09 PM
P
Porter67 Offline
Porter67  Offline
P
Sure there is always one step better everything, one could say the same thing about a oem front end vs a modern lightweight coil over front end, carb vs fi, ect.
Look at all the gimped up, band aided oem blocks hanging on by a wing and a prayer because cheap asses wont pop for the "real" blocks....
A simple 150 plate kit can balance a easy to drive vs a testy hi compression/roller build in alot of cases.
And really unless a well built street or strip car if its not heads up, but a basic bracket car its still back of the bus vs others in alot of ways.
Blah...Blah.....Blah...
And the kicker is for 9 out of 10 of us here vs a well thought out LS car with a cheap boost kit will leave us all thinking.
Were all running old junk, why split hairs over cams.
Re: Purple shaft cams back ordered forever? [Re: ProSport] #2422096
12/21/17 11:46 PM
12/21/17 11:46 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
I second that opinion. up
73 Sport 440, 509 cam w/Eddys 3.91 and 28.1"/27.3 tire. Et. 60 ft. 1.435, 1/8th. 6.61 @ 101.80 mph. 1/4. 10.472 / 127.78 mph. 2950# race/with me,and pump gas.
Re: Purple shaft cams back ordered forever? [Re: Sport440] #2422195
12/22/17 03:24 AM
12/22/17 03:24 AM
Lost in Time
Iowan Offline
Iowan  Offline
Lost in Time
I'd agree also, a few years back I rounded up all the parts from a 440 I built in the 80s, TRWs 9.5, 452 heads with 2.14 1.81s and just a basic blue print. I had a NOS 557 cam on my shelf so in it went, and for kicks and giggles put it on the dyno, 520hp 545tq..
Not bad for motor you could change the cam and springs and put it in an rv.
Have a great day
Iowan
"obsolete is neat"
