Page 1 of 3 1 2 3
motor plate questions #242124
03/03/09 05:30 PM
03/03/09 05:30 PM
Charleston
sixpackgut Offline OP
Drag Week Mod Champion
Charleston
is there a HP point where you should run a motor plate? my engine seems to be twisting too much lately and wondering about buying new mounts or plate it
Re: motor plate questions [Re: sixpackgut] #242125
03/03/09 05:41 PM
03/03/09 05:41 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
How about solid mounts or a limiter?
Re: motor plate questions [Re: sixpackgut] #242126
03/03/09 06:50 PM
03/03/09 06:50 PM
an8sec70cuda Offline
I'm not sure at what HP level one is mandatory, but I'd say around 600-650 hp it's a good idea. Once you use a plate you'll never want to use stock mounts again. At your power level I do think you need one. CHIP
CHIP
'06 GMC 2500HD LBZ Duramax
Re: motor plate questions [Re: sixpackgut] #242127
03/03/09 06:53 PM
03/03/09 06:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Go with the AR Engineering one that AndyF makes You will not find a better one PERIOD!!!
Gus
64 Plymouth Savoy
Dana 60
Re: motor plate questions [Re: sixpackgut] #242128
03/03/09 06:59 PM
03/03/09 06:59 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I was wondering the same thing, I have seen the motor mount ears on the block broken off.
I guess you could install the motor plate with the motor sitting on the motor mounts for locating it, then remove the mounts
Re: motor plate questions [Re: fourgearsavoy] #242129
03/03/09 07:02 PM
03/03/09 07:02 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
pics for you RAY ............ ANDYF moterplater and low mount altenater
1.39 9.85 - 137 mph
Re: motor plate questions [Re: sixpackgut] #242130
03/03/09 07:13 PM
03/03/09 07:13 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Running motor mounts on the side of your block in high HP cars can distort the cylinder walls under power and cause you to loose some power also
Re: motor plate questions [Re: 70blackfish] #242131
03/03/09 08:12 PM
03/03/09 08:12 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The ears break off usually because they went to the
solid mounts and no limiters... the ears cant take
the fore and aft movement of the engine. Even with
a motor plate it is advised that you use limiters
to control the fore and aft movement
Re: motor plate questions [Re: MR_P_BODY] #242132
03/03/09 08:24 PM
03/03/09 08:24 PM
another vote for AndyF motorplate but my 581 hemi is still using stock motor mounts with 850 hp with no problems with a torque strap.
Re: motor plate questions #242133
03/03/09 11:40 PM
03/03/09 11:40 PM
Charleston
Charleston
Ari, thanks for the great pictures. i think i want to put on in. good point on the mount pulling on the cylinders too. it just seems like the engine is about to rotate around and scrape my six pack off the ground
that plate looks nice and thick too
Re: motor plate questions [Re: sixpackgut] #242134
03/03/09 11:58 PM
03/03/09 11:58 PM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
Any pictures of forward and aft supports?
sorry dont mean to Hijack
Re: motor plate questions [Re: 70blackfish] #242135
03/04/09 12:11 AM
03/04/09 12:11 AM
Charleston
Charleston
i wanna see too
Re: motor plate questions [Re: sixpackgut] #242136
03/04/09 05:28 PM
03/04/09 05:28 PM
Charleston
Charleston
what about trans mount? regular rubber or go poly?
Re: motor plate questions [Re: sixpackgut] #242137
03/04/09 05:35 PM
03/04/09 05:35 PM
Wellington, FL
cudabunch Offline
cudabunch  Offline
Wellington, FL
Ray I have Andy's plate with the stock rubber mount trans no problem with my little horses.
Re: motor plate questions [Re: sixpackgut] #242138
03/04/09 06:03 PM
03/04/09 06:03 PM
I have always used a stock tran mount when solid mounting the engine in front with a set of elephant ears per some early instructions at one of the old Mopar performance seminars Never seen a broken tailshaft or other parts failure related to the stock trans mounts
Re: motor plate questions [Re: Cab_Burge] #242139
03/04/09 06:12 PM
03/04/09 06:12 PM
Centerville, MN
schwep Offline
schwep  Offline
Centerville, MN
Attachment to K-Member...Hemi-Style mount on block.
Re: motor plate questions [Re: schwep] #242140
03/04/09 06:35 PM
03/04/09 06:35 PM
long island NY
Ari440 Offline
Ari440  Offline
long island NY
Im using a rubber trannie mount
1.39 9.85 - 137 mph
Re: motor plate questions [Re: schwep] #242141
03/04/09 06:43 PM
03/04/09 06:43 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I have 2 threaded rods(1 on each side) attached to
the mount ears then to the chassis, but I'm changing
them this spring to a nicer set of heim ends on a rod....
mine look ugly now
EDIT
Some of the guys have been mounting the limiters on
the 2 ears on the trans to the frame rails/chassis
Re: motor plate questions [Re: sixpackgut] #242142
03/04/09 06:54 PM
03/04/09 06:54 PM
I have a poly trans mount, no problems.
For the fore/aft limiter I used a Comp Engineering kit and attached one end of the rod to the trans crossmember w/ a 90* bracket and then attached the other end to the transmission case at the rear passenger's side corner just above the pan rail. CHIP
CHIP
Re: motor plate questions [Re: MR_P_BODY] #242143
03/04/09 07:02 PM
03/04/09 07:02 PM
Q
Quicktree Offline
Quicktree  Offline
Q
does anybody know what holds a top fuel motor to the fram rails on the front?
Page 1 of 3 1 2 3
