motor plate questions
#242124
03/03/09 05:30 PM
03/03/09 05:30 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
is there a HP point where you should run a motor plate? my engine seems to be twisting too much lately and wondering about buying new mounts or plate it
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
Re: motor plate questions
[Re: sixpackgut]
#242125
03/03/09 05:41 PM
03/03/09 05:41 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
How about solid mounts or a limiter?
[Re: sixpackgut]
#242126
03/03/09 06:50 PM
03/03/09 06:50 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
I'm not sure at what HP level one is mandatory, but I'd say around 600-650 hp it's a good idea. Once you use a plate you'll never want to use stock mounts again. At your power level I do think you need one. CHIP
[Re: sixpackgut]
#242127
03/03/09 06:53 PM
03/03/09 06:53 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Go with the AR Engineering one that AndyF makes You will not find a better one PERIOD!!! Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: 70blackfish]
#242131
03/03/09 08:12 PM
03/03/09 08:12 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I was wondering the same thing, I have seen the motor mount ears on the block broken off.
I guess you could install the motor plate with the motor sitting on the motor mounts for locating it, then remove the mounts
The ears break off usually because they went to the solid mounts and no limiters... the ears cant take the fore and aft movement of the engine. Even with a motor plate it is advised that you use limiters to control the fore and aft movement
[Re: MR_P_BODY]
#242132
03/03/09 08:24 PM
03/03/09 08:24 PM
another vote for AndyF motorplate but my 581 hemi is still using stock motor mounts with 850 hp with no problems with a torque strap.
#242133
03/03/09 11:40 PM
03/03/09 11:40 PM
sixpackgut
Charleston
Ari, thanks for the great pictures. i think i want to put on in. good point on the mount pulling on the cylinders too. it just seems like the engine is about to rotate around and scrape my six pack off the ground that plate looks nice and thick too
[Re: schwep]
#242141
03/04/09 06:43 PM
03/04/09 06:43 PM
MR_P_BODY
I have 2 threaded rods(1 on each side) attached to the mount ears then to the chassis, but I'm changing them this spring to a nicer set of heim ends on a rod.... mine look ugly now EDIT Some of the guys have been mounting the limiters on the 2 ears on the trans to the frame rails/chassis
[Re: sixpackgut]
#242142
03/04/09 06:54 PM
03/04/09 06:54 PM
an8sec70cuda
I have a poly trans mount, no problems.
For the fore/aft limiter I used a Comp Engineering kit and attached one end of the rod to the trans crossmember w/ a 90* bracket and then attached the other end to the transmission case at the rear passenger's side corner just above the pan rail. CHIP
