What does a tone ring do, and what happens if its gone? #241889
03/03/09 01:38 PM
03/03/09 01:38 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
Ok this may be an odd question, but I need to know what the tone ring does. I was told at one time that it had something to do with the ABS on the rear, but now have found it may have something to do with my speedo?
I am looking at replacing the axles in my 93 RC with 3/4 ton donors from a 77. Will the lack of the tone ring be an issue? Right now the rear ABS is not working and that im not concerned about. However I would like to have a speedo, and wonder if the lack of a speed sensor would cause any issues with a FI engine?
As you may notice Im new to the FI computer stuff, I normally play with the 70's stuff.
Can a tone ring be added to the 77 Dana 60?
Re: What does a tone ring do, and what happens if its g [Re: hp383] #241890
03/03/09 02:02 PM
03/03/09 02:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Is your speedo currently working ? if it is pull the wire off the rear sensor and see what happens , that prepare you .
Re: What does a tone ring do, and what happens if its g [Re: hp383] #241891
03/03/09 02:04 PM
03/03/09 02:04 PM
Chicagoland
chargerron69 Offline
Chicagoland
hang the phone up and check again
sorry i couldnt resist
i am not positive but its probably the ring that the abs sensor reads to tell if the brakes are locked up. if its not working anyway, is should be no problem
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!! 72 Newport 2 door 400 727 85 Ram 440 4 speed O/D 3.54 dana
Re: What does a tone ring do, and what happens if its g [Re: chargerron69] #241892
03/03/09 02:32 PM
03/03/09 02:32 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
no tone ring on the rear diff means no speedo OR RWAL ( abs ) operation
Re: What does a tone ring do, and what happens if its g [Re: gtx6970] #241893
03/03/09 03:13 PM
03/03/09 03:13 PM
Central Coast, Calif.
Snoopy Offline
Snoopy  Offline
Or cruise control
Re: What does a tone ring do, and what happens if its g [Re: Snoopy] #241894
03/03/09 04:51 PM
03/03/09 04:51 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
will no speedo be an issue for the operation of the engine/transmission on a 93?
I currently have speedo, but no cruise, and my ABS light is always on.
Re: What does a tone ring do, and what happens if its g [Re: hp383] #241895
03/03/09 06:54 PM
03/03/09 06:54 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Although I am not 100% certain I would suspect the tone ring is ABS-only and that the transmission or transfer case still has a speed sensor. I know the 96 Dakota we are dismantling has a speed sensor in the same place a speedometer cable would normally go in a vehicle with a mechanical speedometer.
Re: What does a tone ring do, and what happens if its g [Re: Jim_Lusk] #241896
03/03/09 07:05 PM
03/03/09 07:05 PM
State of Confusion
hp383 Offline OP
hp383  Offline OP
State of Confusion
thanks. ill see if i can get someone to look
Re: What does a tone ring do, and what happens if its g [Re: hp383] #241897
03/03/09 08:17 PM
03/03/09 08:17 PM
A tad North of Indy
Blown71X Offline
super gas
Blown71X  Offline
super gas
A tad North of Indy
93 will have a hall effect sensor in the rear of the trans for the speedo..Rear axle sensor is for ABS ONLY and has absolutely nothing to do with anything else.
Speedo operation from the ABS/rear axle sensor did not come around until 1998
Rick
Blown71X V2.0 under construction 71 Cuda 383 4-SPD (maybe for sale) 2010 Challenger B5 Classic
