Re: What does a tone ring do, and what happens if its g
[Re: hp383]
#241891
03/03/09 02:04 PM
03/03/09 02:04 PM
Posts: 549 Chicagoland
chargerron69
Chicagoland
hang the phone up and check again sorry i couldnt resist i am not positive but its probably the ring that the abs sensor reads to tell if the brakes are locked up. if its not working anyway, is should be no problem
67 Coronet 383 hogged out 906's 727 430 dana best 10.48 @126.80 1.47 60 on fogger
same car pump gas 605 wedge 9.98 @ 138.42 1.50 60 on wore out 9 inch radial slick ss springs and frame connectors its got more in it!!!
72 Newport 2 door 400 727
85 Ram 440 4 speed O/D 3.54 dana
[Re: gtx6970]
#241893
03/03/09 03:13 PM
03/03/09 03:13 PM
Posts: 8,850 Central Coast, Calif.
Snoopy
no tone ring on the rear diff means no speedo OR RWAL ( abs ) operation
Or cruise control
[Re: hp383]
#241897
03/03/09 08:17 PM
03/03/09 08:17 PM
Posts: 2,928 A tad North of Indy
Blown71X
super gas
super gas
A tad North of Indy
93 will have a hall effect sensor in the rear of the trans for the speedo..Rear axle sensor is for ABS ONLY and has absolutely nothing to do with anything else.
Speedo operation from the ABS/rear axle sensor did not come around until 1998
Rick
Blown71X V2.0 under construction
71 Cuda 383 4-SPD (maybe for sale)
2010 Challenger B5 Classic
