727 adapter for engine stand #2412302
12/02/17 05:17 PM
12/02/17 05:17 PM
AndyF Offline OP
AndyF  Offline OP
I made one of these a long time ago but it was overkill so I decided to redesign it from sheet metal. This one came out okay but I see some areas I can improve on. It sure makes it easier to work on when you can rotate the trans.
Re: 727 adapter for engine stand [Re: AndyF] #2412320
12/02/17 06:11 PM
12/02/17 06:11 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
You'll need more mods if the ears r cut off for a shield. Maybe make something to bolt to the bell hsg.
Re: 727 adapter for engine stand [Re: AndyF] #2412332
12/02/17 06:56 PM
12/02/17 06:56 PM
Minnesota
R3 Racing Offline
R3 Racing  Offline
Minnesota
Great idea. I would buy one if it would bolt to the bell housing. I have no ears on mine.
Re: 727 adapter for engine stand [Re: R3 Racing] #2412342
12/02/17 07:14 PM
12/02/17 07:14 PM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
iagreex3
Re: 727 adapter for engine stand [Re: AndyF] #2412354
12/02/17 07:47 PM
12/02/17 07:47 PM
est
huimerind Offline
huimerind  Offline
est
My not so pretty version smile
Re: 727 adapter for engine stand [Re: huimerind] #2412380
12/02/17 08:43 PM
12/02/17 08:43 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
That's pretty cool.
Re: 727 adapter for engine stand [Re: AndyF] #2412409
12/02/17 09:21 PM
12/02/17 09:21 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I just use a regular bench mule if it still has the ears. One short and one long bolt with a spacer to hold it square. Bellhousing bolts if the ears are gone. I'll use two pan bolt holes if it's a lightweight 904.
Re: 727 adapter for engine stand [Re: AndyF] #2412410
12/02/17 09:24 PM
12/02/17 09:24 PM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
It needs an eye on the pipe to pick it up with.
Re: 727 adapter for engine stand [Re: justinp61] #2412423
12/02/17 09:43 PM
12/02/17 09:43 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Over the years most of those front ears were cut off both my mopar and powerglide transmissions. I started mounting mine from the tailshaft bolts (tailshaft either on or off) and it works great.
Untitled by John Cadamore, on Flickr
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: 727 adapter for engine stand [Re: justinp61] #2412440
12/02/17 10:18 PM
12/02/17 10:18 PM
AndyF Offline OP
AndyF  Offline OP
I have the eyes for the top rail but I haven't welded them on yet. I also designed a lift fixture for the transmission This makes it easy to pick up and drop into a pickup truck or to lift up on the engine stand. Could also work for a couple of guys to carry a transmission in the pits.
