Re: 727 adapter for engine stand
[Re: AndyF]
#2412409
12/02/17 09:21 PM
12/02/17 09:21 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I just use a regular bench mule if it still has the ears. One short and one long bolt with a spacer to hold it square. Bellhousing bolts if the ears are gone. I'll use two pan bolt holes if it's a lightweight 904.
[Re: justinp61]
#2412423
12/02/17 09:43 PM
12/02/17 09:43 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Over the years most of those front ears were cut off both my mopar and powerglide transmissions. I started mounting mine from the tailshaft bolts (tailshaft either on or off) and it works great. Untitled by John Cadamore, on Flickr Untitled by John Cadamore, on Flickr
[Re: justinp61]
#2412440
12/02/17 10:18 PM
12/02/17 10:18 PM
Posts: 31,023 Oregon
AndyF
It needs an eye on the pipe to pick it up with. I have the eyes for the top rail but I haven't welded them on yet. I also designed a lift fixture for the transmission This makes it easy to pick up and drop into a pickup truck or to lift up on the engine stand. Could also work for a couple of guys to carry a transmission in the pits.
