Starter issues - dead spot?
#2409248
11/26/17 07:53 PM
11/26/17 07:53 PM
Posts: 3,287 Stroudsburg, PA
Erik
Stroudsburg, PA
The starter in my Barracuda is having an issue. The car cranked over fine until today. I turned the key and nothing happened. Not even a click. I checked the battery and it's charged and holds 12.5 volts. I checked the relay and it's fine too.
Could the problem be a faulty ignition switch? Or is there something wrong with the starter. It's a Powermaster mini starter that I installed in 2016.
It did this once before and I popped the clutch to get it going, and it hasn't happened again until now.
Any tricks to get the starter working again?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Starter issues - dead spot?
[Re: Erik]
#2409252
11/26/17 08:01 PM
11/26/17 08:01 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Check for power at the yellow wire on the starter relay when the switch is in the Start position. If there's power there, cross the two threaded lugs on the relay; if the starter turns when those terminals are jumped, the starter is OK and it's likely the relay.
[Re: Erik]
#2409579
11/27/17 01:22 PM
11/27/17 01:22 PM
Posts: 348 Texas Hill Country
Centerline
Texas Hill Country
Take a hammer and tap the starter once or twice. If it starts then the solenoid is the problem. A sticking starter solenoid is a very common problem when all of a sudden it won't crank.
Centerline 64 Dodge Polara 426 Street Wedge - For when I want to go fast 99 Corvette Z-06 - For when I want to turn corners
[Re: Erik]
#2409613
11/27/17 02:43 PM
11/27/17 02:43 PM
Erik
Stroudsburg, PA
It's a 4 spd. I tried the hammer and nothing happened.
I went back inside before I got mad and did something stupid.
[Re: Erik]
#2409654
11/27/17 04:11 PM
11/27/17 04:11 PM
Erik
Stroudsburg, PA
Not yet. Will try when I get home.
[Re: John_Kunkel]
#2409660
11/27/17 04:28 PM
11/27/17 04:28 PM
Posts: 9,066 Eugene, Oregon
minivan
Eugene, Oregon
My 67 was doing this and I just replaced the starter relay.. So far so good...
[Re: Erik]
#2409696
11/27/17 05:33 PM
11/27/17 05:33 PM
Erik
Stroudsburg, PA
I checked the terminals on the relay and the starter to see if they have power.
[Re: Centerline]
#2409738
11/27/17 07:19 PM
11/27/17 07:19 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Take a hammer and tap the starter once or twice. If it starts then the solenoid is the problem. A sticking starter solenoid is a very common problem when all of a sudden it won't crank. FWIW, Last year I had the same problem. A tap on the starter got it working again, so replaced the starter. Long story short, the original negative battery cable was the actual culprit. Robert
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
[Re: Erik]
#2410068
11/28/17 12:33 PM
11/28/17 12:33 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
I checked the terminals on the relay and the starter to see if they have power. Did you have power on the yellow wire at the starter relay ? If it is a starter problem in the windings then you should still hear the relay and the starter solenoid click once when the key is turned to start even though the solenoid pull-in winding grounds through the starter motor circuit. If you hear nothing then it sounds like no power is getting to the starter solenoid from the starter relay. Ron
[Re: Erik]
#2410144
11/28/17 03:07 PM
11/28/17 03:07 PM
Erik
Stroudsburg, PA
I haven't gotten out to do all the tests on the wiring, but last night I decided just for giggles to go out and see what would happen. On the first turn of the key, the starter worked. So I turned off the key before the car started. Then I tried again and nothing. This looks more and more like the starter relay. Hope to get in the testing tonight.
No clutch safety switch on the car.
[Re: Erik]
#2410311
11/28/17 09:18 PM
11/28/17 09:18 PM
RapidRobert
I would (1) do Stumpys' test (2) pull the female connector off of the "grn" starter relay male terminal & jump the male terminal to ground & see if it will crank with the key). (3) in park/ebrake on, pull the yellow wire female connector off of the male "ign" terminal & jump 12V to that male terminal & see if it cranks. If no cranking then (4) jump from the starter relay large "batt" terminal to the nearby brown wire terminal & see if it cranks. If no crank in (4) then (5) down at the starter jump the big to the small terminal & see if it cranks. On (4) I like to clamp one end of the jumper on the threaded stud & touch the other alligator clip to the other brown wire terminal so the sparks dont mess up the threads (2 jumpers is even better & connect the 2 alligator clips for the final connection) & on (5) use 2 jumpers as there are (2) threaded terminals (batt/solenoid) & dont let the alligator clips shift if/when it cranks & touch the starter case. I'm assuming your battery terminals are cleaned.
[Re: Erik]
#2413021
12/04/17 12:52 PM
12/04/17 12:52 PM
Erik
Stroudsburg, PA
Replaced the starter relay and everything looks ok now. No problems since the swap.
Thanks, everyone!
