The starter in my Barracuda is having an issue. The car cranked over fine until today. I turned the key and nothing happened. Not even a click. I checked the battery and it's charged and holds 12.5 volts. I checked the relay and it's fine too.
Could the problem be a faulty ignition switch? Or is there something wrong with the starter. It's a Powermaster mini starter that I installed in 2016.
It did this once before and I popped the clutch to get it going, and it hasn't happened again until now.
Any tricks to get the starter working again?
