Starter issues - dead spot? #2409248
11/26/17 07:53 PM
11/26/17 07:53 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
The starter in my Barracuda is having an issue. The car cranked over fine until today. I turned the key and nothing happened. Not even a click. I checked the battery and it's charged and holds 12.5 volts. I checked the relay and it's fine too.
Could the problem be a faulty ignition switch? Or is there something wrong with the starter. It's a Powermaster mini starter that I installed in 2016.
It did this once before and I popped the clutch to get it going, and it hasn't happened again until now.
Any tricks to get the starter working again?
1970 Challenger Convertible soon to be T/A convertible
Contrary to the opinions of some, I am not dumber than I look.
Re: Starter issues - dead spot? [Re: Erik] #2409252
11/26/17 08:01 PM
11/26/17 08:01 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check for power at the yellow wire on the starter relay when the switch is in the Start position. If there's power there, cross the two threaded lugs on the relay; if the starter turns when those terminals are jumped, the starter is OK and it's likely the relay.
Re: Starter issues - dead spot? [Re: Erik] #2409579
11/27/17 01:22 PM
11/27/17 01:22 PM
Texas Hill Country
Centerline Offline
Centerline  Offline
Texas Hill Country
Take a hammer and tap the starter once or twice. If it starts then the solenoid is the problem. A sticking starter solenoid is a very common problem when all of a sudden it won't crank.
Centerline
64 Dodge Polara 426 Street Wedge - For when I want to go fast
99 Corvette Z-06 - For when I want to turn corners
Re: Starter issues - dead spot? [Re: Erik] #2409593
11/27/17 01:58 PM
11/27/17 01:58 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
If it's an automatic try holding the key in the start position and shift from park to neutral to see if it may be a linkage adjustment problem..
Re: Starter issues - dead spot? [Re: Erik] #2409613
11/27/17 02:43 PM
11/27/17 02:43 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
It's a 4 spd. I tried the hammer and nothing happened.
I went back inside before I got mad and did something stupid.
Re: Starter issues - dead spot? [Re: Erik] #2409644
11/27/17 03:46 PM
11/27/17 03:46 PM
Grand Prairie,Texas
Grand Prairie,Texas
Did you try what John K suggested?
Re: Starter issues - dead spot? [Re: Erik] #2409654
11/27/17 04:11 PM
11/27/17 04:11 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Not yet. Will try when I get home.
Re: Starter issues - dead spot? [Re: John_Kunkel] #2409660
11/27/17 04:28 PM
11/27/17 04:28 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
My 67 was doing this and I just replaced the starter relay.. So far so good...
Re: Starter issues - dead spot? [Re: Erik] #2409683
11/27/17 05:15 PM
11/27/17 05:15 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
When you checked the did you check the terminals ?
Re: Starter issues - dead spot? [Re: Erik] #2409696
11/27/17 05:33 PM
11/27/17 05:33 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I checked the terminals on the relay and the starter to see if they have power.
Re: Starter issues - dead spot? [Re: Centerline] #2409738
11/27/17 07:19 PM
11/27/17 07:19 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
FWIW, Last year I had the same problem. A tap on the starter got it working again, so replaced the starter. Long story short, the original negative battery cable was the actual culprit. rant hammer
Robert
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: Starter issues - dead spot? [Re: Erik] #2409748
11/27/17 07:43 PM
11/27/17 07:43 PM
P
Paul_Fancsali Offline
P
Clutch safety switch will cause a issue for a stick car you can ground the wire at starter relay and by pass the switch
Re: Starter issues - dead spot? [Re: Erik] #2410068
11/28/17 12:33 PM
11/28/17 12:33 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Did you have power on the yellow wire at the starter relay ? If it is a starter problem in the windings then you should still hear the relay and the starter solenoid click once when the key is turned to start even though the solenoid pull-in winding grounds through the starter motor circuit. If you hear nothing then it sounds like no power is getting to the starter solenoid from the starter relay. Ron
Re: Starter issues - dead spot? [Re: 383man] #2410083
11/28/17 12:53 PM
11/28/17 12:53 PM
moparx Offline
moparx  Offline
i've had a bad wire from the relay to the starter solenoid cause this exact problem [no click] many times over the years. it can be the wire itself, or the terminal to the wire connection at either end.
beer
Re: Starter issues - dead spot? [Re: Erik] #2410144
11/28/17 03:07 PM
11/28/17 03:07 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
I haven't gotten out to do all the tests on the wiring, but last night I decided just for giggles to go out and see what would happen. On the first turn of the key, the starter worked. So I turned off the key before the car started. Then I tried again and nothing. This looks more and more like the starter relay. Hope to get in the testing tonight.
No clutch safety switch on the car.
Re: Starter issues - dead spot? [Re: Erik] #2410311
11/28/17 09:18 PM
11/28/17 09:18 PM
I would (1) do Stumpys' test (2) pull the female connector off of the "grn" starter relay male terminal & jump the male terminal to ground & see if it will crank with the key). (3) in park/ebrake on, pull the yellow wire female connector off of the male "ign" terminal & jump 12V to that male terminal & see if it cranks. If no cranking then (4) jump from the starter relay large "batt" terminal to the nearby brown wire terminal & see if it cranks. If no crank in (4) then (5) down at the starter jump the big to the small terminal & see if it cranks. On (4) I like to clamp one end of the jumper on the threaded stud & touch the other alligator clip to the other brown wire terminal so the sparks dont mess up the threads (2 jumpers is even better & connect the 2 alligator clips for the final connection) & on (5) use 2 jumpers as there are (2) threaded terminals (batt/solenoid) & dont let the alligator clips shift if/when it cranks & touch the starter case. I'm assuming your battery terminals are cleaned.
Re: Starter issues - dead spot? [Re: Erik] #2413021
12/04/17 12:52 PM
12/04/17 12:52 PM
Stroudsburg, PA
Erik Offline OP
Erik  Offline OP
Stroudsburg, PA
Replaced the starter relay and everything looks ok now. No problems since the swap.
Thanks, everyone!
