Page 3 of 4 1 2 3 4
Re: Hemi compression ration [Re: Lost in life] #2405976
11/19/17 04:40 PM
11/19/17 04:40 PM
nielsville, minn.
Q
quickd100 Offline
quickd100  Offline
Q
nielsville, minn.
With 2.2 rod journals you could probably do internal oiling. I have a Million dual line external system. The stroke is 4.75. one one downside is real short piston skirts. After having both a 528 and a 605 I'd never go back. My motor made 765 ft lbs at 3500 rpm and peaked at 818 ft lbs.
Re: Hemi compression ration [Re: Lost in life] #2405983
11/19/17 04:55 PM
11/19/17 04:55 PM
Everywhere
Lost in life Offline OP
Everywhere
Wow...that would set you back in the seat! Thanks for the information.
Re: Hemi compression ration [Re: Lost in life] #2406046
11/19/17 08:06 PM
11/19/17 08:06 PM
Me thinks them kind of motors spin the tire pretty easily and regularly devil work
Re: Hemi compression ration [Re: Lost in life] #2406081
11/19/17 09:48 PM
11/19/17 09:48 PM
Everywhere
Everywhere
Yeah, I think that is part of the fun! If you do get traction better have bead locks or screwed rims!
Re: Hemi compression ration [Re: Lost in life] #2406177
11/20/17 01:32 AM
11/20/17 01:32 AM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
I got my Stage V heads from Tim at FHO , didn't take very long to CNC assemble and ship. Give him a call, he'll tell you the wait time as he does the heads to your specs..
Re: Hemi compression ration [Re: Lost in life] #2406211
11/20/17 03:19 AM
11/20/17 03:19 AM
California
mickm Offline
mickm  Offline
California
I agree with most people so far. Mine is a 540, Stage V heads, and made 712hp @ 6k on 91.
You will simply not be able to make use of 700 hp on a street setup. 800 will just be worse. It's fun to say you have it, but that's about it...
Re: Hemi compression ration [Re: Lost in life] #2406287
11/20/17 12:18 PM
11/20/17 12:18 PM
an8sec70cuda Offline
My 572 is a lil over 11:1 and runs great on pump gas. It's been 9.50s at 140 mph on the motor. When I want to go fast, I put race fuel in it and use the nitrous to go 8.90s at 150 mph.
My previous engine was 14:1 and ran on C12...it was streetable, but a huge PITA w/ it being strictly a race fuel engine. I ran into Jim Pranis at the Mopar Nats right after he'd finished his big pump gas hemi build. We got to talking about it and I decided I had to have one.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Hemi compression ration [Re: Lost in life] #2406319
11/20/17 01:34 PM
11/20/17 01:34 PM
Everywhere
Everywhere
Thanks for all the replies. After a bit of soul searching and a reality check I decided I will go with a motor that has between 10.5-11.5 compression ratio. In all probability I will never use the full potential of the horsepower and torque that motor will bring to my Dart. I have a call into the engine builder and will discuss with him for further clarification and advice. Thanks again.
Re: Hemi compression ration [Re: Lost in life] #2406326
11/20/17 01:59 PM
11/20/17 01:59 PM
Ohio
lockjaw-express Offline
Ohio
Chip, what gear ratio and tire diameter are you running on your 572?
Re: Hemi compression ration [Re: lockjaw-express] #2406383
11/20/17 04:16 PM
11/20/17 04:16 PM
4.10 gear and a 30" dia. tire (295-65 radial).
CHIP
Re: Hemi compression ration [Re: Lost in life] #2406461
11/20/17 06:30 PM
11/20/17 06:30 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 528" Hemi is a 10.5:1 Pump gas engine & still made 853 / 691 on pump gas (93 Octane).
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Hemi compression ration [Re: 6PKRTSE] #2406469
11/20/17 06:52 PM
11/20/17 06:52 PM
Houston,Tx.
Lee446 Offline
Lee446  Offline
Houston,Tx.
Mine made almost exactly the same numbers as Micks, what I learned real quick is that you better be running Drag radials on the street or you can get in trouble quick!
Re: Hemi compression ration [Re: Lost in life] #2406476
11/20/17 07:10 PM
11/20/17 07:10 PM
Everywhere
Everywhere
So would you mind sharing the build specs to get those big numbers? I am most likely going to try to run some kind of slick on the street...No body really bothers you around here unless you are being a dumb a** and causing issues.
Re: Hemi compression ration [Re: Lost in life] #2406531
11/20/17 10:00 PM
11/20/17 10:00 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
How much can the stock street head stand? Mines 4.31x4.5 crank, what's the total advance you run? I'm all ears.
Re: Hemi compression ration [Re: Lost in life] #2406637
11/21/17 02:27 AM
11/21/17 02:27 AM
New York
polyspheric Offline
polyspheric  Offline
New York
High compression is going to be more knock sensitive with a standard transmission:
1. depending on your "crawl ratio" (1st gear X axle ratio)
2. flywheel weight
3. advance curve
Boffin Emeritus
Re: Hemi compression ration [Re: Lee446] #2406646
11/21/17 02:47 AM
11/21/17 02:47 AM
I had the exact opposite experience with my old pump gas Duster, it would spin the snot out of the M/T ET Street radials on the street, on a decent to good track they where faster than the same size ET Street bias ply where up
On the street the bias ply tires where a lot easier to hook and wouldn't bust loose in high gear like the radials would work shruggy
That 518 C.I. 400 stroker Indy headed motor made a tad bit above 725 HP and similar torque, not a real street killer shruggy
Re: Hemi compression ration [Re: Cab_Burge] #2406721
11/21/17 11:31 AM
11/21/17 11:31 AM
iagree Drag radials are still like driving on ice on the street...they don't work on the highway. If you want street traction, you have to go w/ a bias ply tire.
CHIP
Re: Hemi compression ration [Re: Lost in life] #2406759
11/21/17 12:45 PM
11/21/17 12:45 PM
North of Detroit
HemiDart68 Offline
HemiDart68  Offline
North of Detroit
Been there done it with a street car. Went from 750 hp wedge to 1000 hp high compression hemi in my street strip car. For drag racing do the high compression. My car with 1000 hp was not fun on the street. Would blow the tires off in any gear. Was in the limiter before he pedal was half way down. Raced a 12 second car on the street and almost got beat because all I did was spin. Took that motor down to pump gas and small cam. 605 cu inch. 850 hp with pump gas. Car is a blast to drive now on the street. I don’t fear race gas and compression on the street. I just think when u get over 800 on the street the fun factor goes away.
In God we trust, all others pay cash. www.lightnens.com (Home of the world's fastest Paint Job)
Re: Hemi compression ration [Re: Lost in life] #2406799
11/21/17 01:45 PM
11/21/17 01:45 PM
Everywhere
Everywhere
I think for my needs a 700 HP/torque motor will do everything I want it to do. Yet, I want to make sure the local mustang and hellcat boys don't make the car look silly if push comes to shove. Ego is a terrible thing. Thanks for the replies.
Re: Hemi compression ration [Re: Lost in life] #2406858
11/21/17 03:18 PM
11/21/17 03:18 PM
NE Ohio
DoubleD Offline
DoubleD  Offline
NE Ohio
"Ego is a terrible thing" Especially with a HEMI! Go big or Go Home!
For street you can always go fuel injection and put a MSD grid in it - then you can program it for a given power level - many ways to do things even with the cross ram you plan to use - the technology is out there.
Page 3 of 4 1 2 3 4
