Re: Hemi compression ration
[Re: Lost in life]
#2406177
11/20/17 01:32 AM
11/20/17 01:32 AM
Posts: 6,257 gulfport, ms, west mi
rowin4
I got my Stage V heads from Tim at FHO , didn't take very long to CNC assemble and ship. Give him a call, he'll tell you the wait time as he does the heads to your specs..
[Re: Lost in life]
#2406287
11/20/17 12:18 PM
11/20/17 12:18 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
My 572 is a lil over 11:1 and runs great on pump gas. It's been 9.50s at 140 mph on the motor. When I want to go fast, I put race fuel in it and use the nitrous to go 8.90s at 150 mph. My previous engine was 14:1 and ran on C12...it was streetable, but a huge PITA w/ it being strictly a race fuel engine. I ran into Jim Pranis at the Mopar Nats right after he'd finished his big pump gas hemi build. We got to talking about it and I decided I had to have one.
[Re: lockjaw-express]
#2406383
11/20/17 04:16 PM
11/20/17 04:16 PM
an8sec70cuda
Chip, what gear ratio and tire diameter are you running on your 572? 4.10 gear and a 30" dia. tire (295-65 radial).
[Re: Lost in life]
#2406461
11/20/17 06:30 PM
11/20/17 06:30 PM
Posts: 4,569 Motor City
6PKRTSE
Motor City
My 528" Hemi is a 10.5:1 Pump gas engine & still made 853 / 691 on pump gas (93 Octane).
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
[Re: Lost in life]
#2406637
11/21/17 02:27 AM
11/21/17 02:27 AM
Posts: 4,208 New York
polyspheric
New York
High compression is going to be more knock sensitive with a standard transmission: 1. depending on your "crawl ratio" (1st gear X axle ratio) 2. flywheel weight 3. advance curve
Boffin Emeritus
[Re: Lee446]
#2406646
11/21/17 02:47 AM
11/21/17 02:47 AM
Posts: 43,218 Bend,OR USA
Cab_Burge
what I learned real quick is that you better be running Drag radials on the street or you can get in trouble quick! I had the exact opposite experience with my old pump gas Duster, it would spin the snot out of the M/T ET Street radials on the street, on a decent to good track they where faster than the same size ET Street bias ply where On the street the bias ply tires where a lot easier to hook and wouldn't bust loose in high gear like the radials would That 518 C.I. 400 stroker Indy headed motor made a tad bit above 725 HP and similar torque, not a real street killer
[Re: Cab_Burge]
#2406721
11/21/17 11:31 AM
11/21/17 11:31 AM
an8sec70cuda
what I learned real quick is that you better be running Drag radials on the street or you can get in trouble quick! I had the exact opposite experience with my old pump gas Duster, it would spin the snot out of the M/T ET Street radials on the street, on a decent to good track they where faster than the same size ET Street bias ply where On the street the bias ply tires where a lot easier to hook and wouldn't bust loose in high gear like the radials would That 518 C.I. 400 stroker Indy headed motor made a tad bit above 725 HP and similar torque, not a real street killer Drag radials are still like driving on ice on the street...they don't work on the highway. If you want street traction, you have to go w/ a bias ply tire.
[Re: Lost in life]
#2406759
11/21/17 12:45 PM
11/21/17 12:45 PM
Posts: 4,866 North of Detroit
HemiDart68
North of Detroit
Been there done it with a street car. Went from 750 hp wedge to 1000 hp high compression hemi in my street strip car. For drag racing do the high compression. My car with 1000 hp was not fun on the street. Would blow the tires off in any gear. Was in the limiter before he pedal was half way down. Raced a 12 second car on the street and almost got beat because all I did was spin. Took that motor down to pump gas and small cam. 605 cu inch. 850 hp with pump gas. Car is a blast to drive now on the street. I don’t fear race gas and compression on the street. I just think when u get over 800 on the street the fun factor goes away.
In God we trust, all others pay cash.
www.lightnens.com (Home of the world's fastest Paint Job)
