Small bolt pattern wheel question #2402550
11/12/17 03:14 PM
11/12/17 03:14 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
I picked up this Western Sport Special Dart with what looks to be the factory rims. They are wider than the normal sbp wheels yet very different looking than the 5.5" wheels. Anyone know what these are?
www.Musclemagnet.com
1969 Cuda 383 Q5
1969 Cuda 340 4-spd Notch
1969 Cuda 383 4-spd Notch
1969 GTS Black on White 340 4-spd
1971 Cuda 383 V2, X9 Billboards, White Top!
Re: Small bolt pattern wheel question [Re: 694406] #2402685
11/12/17 08:05 PM
11/12/17 08:05 PM
Sacramento CA
Morty426 Offline
Morty426  Offline
Sacramento CA
It looks like a 1968 wheel to me, check near the valve stem to see if it calls out the width either 5.5 or 6.0
Re: Small bolt pattern wheel question [Re: Morty426] #2403867
11/15/17 07:36 AM
11/15/17 07:36 AM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
LA had a different plant for some of their wheels - so they may look a little different than what you are used to seeing
V8 with disc brakes or A/C should have sbp 14x5.5"
Re: Small bolt pattern wheel question [Re: 694406] #2403959
11/15/17 02:08 PM
11/15/17 02:08 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Forget the darts wheels! What about those trailer wheels! Never saw someone run big and littles on their trailer! smile
best of 11.39 at 117 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: Small bolt pattern wheel question [Re: 694406] #2404114
11/15/17 06:48 PM
11/15/17 06:48 PM
blewbyu Online content
blewbyu  Online Content
I have a 68 GTS with that same wheels and I was also confused.
Re: Small bolt pattern wheel question [Re: blewbyu] #2404272
11/15/17 11:26 PM
11/15/17 11:26 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I don't believe I have ever seen those wheels. They look like 13" centers on 14" wheels to me! You silly Kalifornikans make some strange stuff... shruggy
JB Rhinehart, Realist
A-Body's RULE!
Re: Small bolt pattern wheel question [Re: FurryStump] #2404382
11/16/17 04:01 AM
11/16/17 04:01 AM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
If you actually knew Joe you'd understand. whistling
Obviously cheap used tires are the reason why.
That or he hoping to start a new trend of big and little's on trailers. laugh2
Re: Small bolt pattern wheel question [Re: 694406] #2404627
11/16/17 09:30 PM
11/16/17 09:30 PM
St.Louis, MO
694406 Offline OP
694406  Offline OP
St.Louis, MO
Well crap! If Jim (Rhinodart) doesn't know now I'm really puzzled! I guess I should keep them because as soon as I'd sell the car they'd turn out to be something I shouldn't have let go!
Are you going to MCACN Jim? I'f I'm motivated enough in the morning I'll pull one off & bring it.
As far as the trailer tires it shadowing and the way the trailer is torqued into the lane at the gas station!
1969 Cuda 383 Q5
Re: Small bolt pattern wheel question [Re: 694406] #2405302
11/18/17 02:37 AM
11/18/17 02:37 AM
Highland, MI.
Sunroofcuda Offline
Sunroofcuda  Offline
Highland, MI.
Here is a 68-9 date coded 14x5.5" large (4.5") BP wheel - the bumps in-between the lug holes are very distinctive:
http://www.classicchambered.com/rims/14X55.jpg
Re: Small bolt pattern wheel question [Re: 694406] #2405476
11/18/17 03:26 PM
11/18/17 03:26 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
? the placard in the photo says 3.75" bolt circle.
Re: Small bolt pattern wheel question [Re: kentj340] #2405488
11/18/17 03:53 PM
11/18/17 03:53 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
No, the Placard says bolt space, not bolt circle. Big difference.
'69 Dart should be standard bolt pattern. 5 bolt X 4.5 inch circle.
As for those wheels I have no clue.
I have mechanical Aptitude.
I can screw up anything.
Re: Small bolt pattern wheel question [Re: bboogieart] #2405495
11/18/17 04:06 PM
11/18/17 04:06 PM
God's Country Maryland
GODSCOUNTRY340 Offline
Bolt pattern on a '69 Dart would be 5 bolt x 4" bolt circle.
Re: Small bolt pattern wheel question [Re: GODSCOUNTRY340] #2405498
11/18/17 04:12 PM
11/18/17 04:12 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Quote "bolt pattern on a '69 Dart would be 5 bolt x 4" bolt circle."
Oops. Not that familiar with A bodies.
When did they get the Bigger size?
Re: Small bolt pattern wheel question [Re: 694406] #2405515
11/18/17 04:57 PM
11/18/17 04:57 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
I'm now restoring the wheels on my one owner '69 Hamtramck Barracuda with 14 x 5.5 wheels.
3 are original factory wheels of 11/11/68 and 11/12/68, and 2 are parts counter wheels of 7/24/70 and 12/23/71, because my then wife wiped out 2 on a curb.
The 3 original 1968 wheels have shallow bosses between the lug holes, and the ends toward the center of rotation are pointy.
The '70 and '71 wheels have bigger bosses with round ends.
Top 2 photos show original '68 wheels first, '70 and '71 wheels below.
Re: Small bolt pattern wheel question [Re: kentj340] #2405517
11/18/17 05:03 PM
11/18/17 05:03 PM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
All 5 wheels were made in Canada. The 3 original wheels and one of the parts counter wheels have 8 big spot welds. The 12/23/71 wheel has 4 automated bead welds.
Re: Small bolt pattern wheel question [Re: bboogieart] #2405568
11/18/17 06:47 PM
11/18/17 06:47 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
1973 was the first year that production A body cars were available with the standard Mopar 4.5 inch bolt circle.
Now....At that time, there were still 4 wheel drum cars both the 9 inch front and 10 inch front. There is some that say that after 1974, no front drum cars were built. I have owned more than one 1975-76 car with small 9 inch drums at all four wheels. There has been debate that since the Mopar parts catalogs didn't list front drums for 1975 and 1976 cars, they were not built. Believe what you want, I owned two. I've also seen numerous 75-76 cars in wrecking yards with 4 wheel drum brakes. Also, ALL 4 wheel drum A body cars were small bolt pattern.
Re: Small bolt pattern wheel question [Re: Kern Dog] #2405619
11/18/17 08:03 PM
11/18/17 08:03 PM
Lost and Spaced
bboogieart Offline
bboogieart  Offline
Lost and Spaced
Thanx up
Always glad to learn.
