Fool proof exhaust manifold gasket #2403979
11/15/17 02:53 PM
11/15/17 02:53 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I remember seeing some header gaskets that were pricey but leak proof mention on the site. I’ve got a stock manifold that I cannot get to seal. Any body help me out with what they use?
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2403988
11/15/17 03:03 PM
11/15/17 03:03 PM
Washington
madscientist Offline
Washington
Remflex
Re: Fool proof exhaust manifold gasket [Re: madscientist] #2404006
11/15/17 03:49 PM
11/15/17 03:49 PM
MD.
V
vttm Offline
vttm  Offline
V
MD.
Originally Posted By madscientist
Remflex
^^^^^This^^^^^
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404028
11/15/17 04:44 PM
11/15/17 04:44 PM
Cotati, CA
Dave Hall Offline
Dave Hall  Offline
Cotati, CA
Either the exhaust manifold is warped or the surface of the head is not flat. Two correctly machined surfaces should ultimately need no gasket for exhaust. Just bite the bullet and get the two parts correctly done and you won't fight it for the life of the car.
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404228
11/15/17 10:06 PM
11/15/17 10:06 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Copper RTV
Re: Fool proof exhaust manifold gasket [Re: vttm] #2404260
11/15/17 10:51 PM
11/15/17 10:51 PM
jersey
Spaceman Spiff Offline
jersey
Remflex
^^^^^This^^^^^
another vote for Remflex
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Fool proof exhaust manifold gasket [Re: madscientist] #2404274
11/15/17 11:28 PM
11/15/17 11:28 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
Remflex
Ditto....And what I do to get my junk to seal, I red rtv the gaskets to the heads and let them sit 24hrs...
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404283
11/15/17 11:44 PM
11/15/17 11:44 PM
MI, usa
dvw Online content
dvw  Online Content
MI, usa
The manifold needs to come off anyway. 99% chance it's not flat. Perfect time to get it machined.
Doug
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404485
11/16/17 02:07 PM
11/16/17 02:07 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Fel-pro blue perma-torque gaskets here forever installed w/just a smear of grease and a couple re-torques..........no leaks ever BUT the flanges need to be flat.......... beer
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404650
11/16/17 10:27 PM
11/16/17 10:27 PM
Medina, OH
dart440_72 Offline
dart440_72  Offline
Medina, OH
Remflex as well. I had a lot of problems sealing up some old headers. These worked great. They are not reusable though.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404813
11/17/17 02:48 AM
11/17/17 02:48 AM
Washington
skrews Offline
skrews  Offline
Washington
Re: Fool proof exhaust manifold gasket [Re: FastmOp] #2404815
11/17/17 02:53 AM
11/17/17 02:53 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Originally Posted By FastmOp
Copper RTV
My vote as well.
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404877
11/17/17 10:54 AM
11/17/17 10:54 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve got the remflex in last night but they are so thick, I’m afraid the nuts wont engage the threads enough. Do they squish a lot?
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404913
11/17/17 12:25 PM
11/17/17 12:25 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
They do squish a bit but not a lot. Look at the pic I posted to AndyF's thread on the Milodon Sandwich Plate ... you can see the Remflex Gaskets torqued down and how much they squish (not much). I'm using Percy's locking header bolts that are 3/4" long (https://www.summitracing.com/parts/php-310014/overview/) and there is plenty of thread engagement. And I've had these headers on and off while reusing the gasket and never had a leak. I HATE header leaks ... they drive me nuts!! My heads are aluminum but the gaskets didn't stick when I removed/reinstalled the headers. My experience is that as long as you put them back on with the same headers and in the same orientation, they can be reused. They have a sort of non-stick graphite coating on them. If you are running iron heads with studs, you might have to put in studs that are just a bit longer. Not sure if they might stick to cast iron after a bunch of heat cycles.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Fool proof exhaust manifold gasket [Re: fastmark] #2404949
11/17/17 01:44 PM
11/17/17 01:44 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I can’t use longer studs. It just barely comes off enough to get the manifold off the studs. The pass side is way close to the shock tower. This car is “killing me, Smalls”!!!!
Re: Fool proof exhaust manifold gasket [Re: Neil] #2405532
11/18/17 05:28 PM
11/18/17 05:28 PM
mt. pleasant, PA
Diplomat440 Offline
Diplomat440  Offline
mt. pleasant, PA
Copper RTV
My vote as well.
Same here. Never have any leaks.
