Re: Fool proof exhaust manifold gasket
[Re: madscientist]
#2404006
11/15/17 03:49 PM
11/15/17 03:49 PM
Posts: 188 MD.
vttm
MD.
[Re: fastmark]
#2404650
11/16/17 10:27 PM
11/16/17 10:27 PM
Posts: 314 Medina, OH
dart440_72
Medina, OH
Remflex as well. I had a lot of problems sealing up some old headers. These worked great. They are not reusable though.
72 Dart 500" low deck Indy SR heads. 10.40 @129 best so far
[Re: fastmark]
#2404877
11/17/17 10:54 AM
11/17/17 10:54 AM
Posts: 6,426 Abilene, Texas
fastmark
Abilene, Texas
I’ve got the remflex in last night but they are so thick, I’m afraid the nuts wont engage the threads enough. Do they squish a lot?
[Re: fastmark]
#2404913
11/17/17 12:25 PM
11/17/17 12:25 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
I’ve got the remflex in last night but they are so thick, I’m afraid the nuts wont engage the threads enough. Do they squish a lot? They do squish a bit but not a lot. Look at the pic I posted to AndyF's thread on the Milodon Sandwich Plate ... you can see the Remflex Gaskets torqued down and how much they squish (not much). I'm using Percy's locking header bolts that are 3/4" long ( https://www.summitracing.com/parts/php-310014/overview/) and there is plenty of thread engagement. And I've had these headers on and off while reusing the gasket and never had a leak. I HATE header leaks ... they drive me nuts!! My heads are aluminum but the gaskets didn't stick when I removed/reinstalled the headers. My experience is that as long as you put them back on with the same headers and in the same orientation, they can be reused. They have a sort of non-stick graphite coating on them. If you are running iron heads with studs, you might have to put in studs that are just a bit longer. Not sure if they might stick to cast iron after a bunch of heat cycles.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
