Milodon oil inlet plate? #2404638
11/16/17 09:58 PM
11/16/17 09:58 PM
AndyF Online content OP
AndyF  Online Content OP
I don't have an old catalog anymore and it doesn't look like Milodon has these sandwich plates in the new catalog. Anyone remember the part number and/or have a picture of the inlet plate? It was a cast plate that went between the block and the pump and provided a place for a #12 line to hook up.
Re: Milodon oil inlet plate? [Re: AndyF] #2404655
11/16/17 10:38 PM
11/16/17 10:38 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
This one??
Milodon part # 21350
https://www.summitracing.com/parts/mil-21350
Re: Milodon oil inlet plate? [Re: AndyF] #2404683
11/16/17 11:25 PM
11/16/17 11:25 PM
Yep, that is it. I was told that it wasn't available anymore but it looks like it is in stock. Thanks.
Re: Milodon oil inlet plate? [Re: AndyF] #2404749
11/17/17 12:36 AM
11/17/17 12:36 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
I never understood using that plate. The plate is $104 and a new Melling pump is $80. you can buy the Milodon aluminum pump for $185 and put a stock cover on it.
Re: Milodon oil inlet plate? [Re: AndyF] #2404754
11/17/17 12:40 AM
11/17/17 12:40 AM
I don't, and won't use that plate tsk
The cast aluminum Milidon pump with the cast in 12 AN fitting boss supplies a lot more oil to that pump than the plate can supply to a stock type pump work
Re: Milodon oil inlet plate? [Re: AndyF] #2404844
11/17/17 05:19 AM
11/17/17 05:19 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
What do you use for a pump drive if spacing the pump away from the block?
Re: Milodon oil inlet plate? [Re: 451Mopar] #2404852
11/17/17 07:42 AM
11/17/17 07:42 AM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Longer distributor/oil pump drive shafts .....they should still be available from milodon
Re: Milodon oil inlet plate? [Re: AndyF] #2404905
11/17/17 12:02 PM
11/17/17 12:02 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Well, AndyF, you must have a specific reason for wanting this non-optimal solution. If you really want one of those plates, I'll yank the one off my B engine and ship it to your door for $50 credit on my account wink It would be nice for you to buy a part from me after all of the cool parts I've bought from you!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Milodon oil inlet plate? [Re: fbs63] #2404915
11/17/17 12:29 PM
11/17/17 12:29 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
Well, that's the only way you could have bought a dual line oil system nearly 50 years ago when it came out. That fed the bottom of the pump and the Milodon top cover fed the top of the pump. That's what every Super Stock or Pro Stock car had on it. There are better ways today, like using the oil pump Cab was talking about and a billet top cover.
2011 Drag Pak Challenger
Re: Milodon oil inlet plate? [Re: AndyF] #2405139
11/17/17 07:44 PM
11/17/17 07:44 PM
Tim at FHO is looking for some of those plates so he can finish some engine builds. He called me to see if I had any or could make some but I didn't have any and evidently nobody else has them in stock. Milodon is out and Summit said they had them in stock but when Tim checked they didn't actually have any.
If anyone has an inlet plate in good shape that they are willing to sell then let Tim know. He is also looking for some of the cast Milodon oil pumps with the external inlet. I sold the last ones that I had but he needs more.
Re: Milodon oil inlet plate? [Re: AndyF] #2405149
11/17/17 07:56 PM
11/17/17 07:56 PM
Los Angeles, California
mdeane Offline
mdeane  Offline
Glendora Dodge has 1 of those plates new in the package.
Re: Milodon oil inlet plate? [Re: AndyF] #2405216
11/17/17 11:05 PM
11/17/17 11:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
you can run the inside pick-up with the outside #12 cover. the early front engine gen2 hemi fuelers did this. I've done some bracket motors with this. poor man's dual line.
Re: Milodon oil inlet plate? [Re: lewtot184] #2405269
11/18/17 01:25 AM
11/18/17 01:25 AM
Wisconsin
StageIII Offline
StageIII  Offline
Wisconsin
Is that the plate the gasket would blow out?
Re: Milodon oil inlet plate? [Re: StageIII] #2405271
11/18/17 01:28 AM
11/18/17 01:28 AM
No, the gasket that failed was always the green gasket between the top pump cover and the oil filter adapter plate on the pressure side.
That bottom adapter hose plate is on the suction side of that system scope
