Re: Milodon oil inlet plate?
[Re: 451Mopar]
#2404852
11/17/17 07:42 AM
11/17/17 07:42 AM
Posts: 1,229 In The Hills
jughed
In The Hills
What do you use for a pump drive if spacing the pump away from the block? Longer distributor/oil pump drive shafts .....they should still be available from milodon
[Re: AndyF]
#2404905
11/17/17 12:02 PM
11/17/17 12:02 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Well, AndyF, you must have a specific reason for wanting this non-optimal solution. If you really want one of those plates, I'll yank the one off my B engine and ship it to your door for $50 credit on my account It would be nice for you to buy a part from me after all of the cool parts I've bought from you!
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: fbs63]
#2404915
11/17/17 12:29 PM
11/17/17 12:29 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I never understood using that plate. Well, that's the only way you could have bought a dual line oil system nearly 50 years ago when it came out. That fed the bottom of the pump and the Milodon top cover fed the top of the pump. That's what every Super Stock or Pro Stock car had on it. There are better ways today, like using the oil pump Cab was talking about and a billet top cover.
2011 Drag Pak Challenger
[Re: StageIII]
#2405271
11/18/17 01:28 AM
11/18/17 01:28 AM
Posts: 43,205 Bend,OR USA
Cab_Burge
Is that the plate the gasket would blow out? No, the gasket that failed was always the green gasket between the top pump cover and the oil filter adapter plate on the pressure side. That bottom adapter hose plate is on the suction side of that system
