FBO ignition and MP electronic ignition
#239991
03/01/09 03:48 PM
03/01/09 03:48 PM
Posts: 347 FRANCE, Paris
Chal340
FRANCE, Paris
I have a MP electronic ignition kit (P3690426) and i would like to know if it’s possible to use the MP distributor with the A688 fbo kit (ECU, coil and ballast resistor).
70 Challenger, A66, 340 ci
Re: FBO ignition and MP electronic ignition
[Re: Chal340]
#239992
03/01/09 03:52 PM
03/01/09 03:52 PM
RapidRobert
Oui qui est un plan excellent & quand vous recevez le droit d'organisation de corbe vous serez en pliene forme
[Re: Chal340]
#239995
03/01/09 04:59 PM
03/01/09 04:59 PM
Posts: 8,020 Pangaea
B5 Bee
Pangaea
I ran the A688 FBO ignition kit with a MP distributor. It ran well at first, then it failed. I bought it 3 or 4 years ago if time frame has anything to do with it. Next ignition I buy is going to be a Mallory Hy-Fire6, it has more features for less money than the MSD equivalent.
[Re: B5 Bee]
#239996
03/01/09 05:26 PM
03/01/09 05:26 PM
Posts: 6,816 Alton, IL
Dakota_Don
Alton, IL
for the money spent I wish i went with msd the first time.. My whole set up from FBO was wrong.. now its costing me double to fix it again..
[Re: Dakota_Don]
#239997
03/01/09 06:12 PM
03/01/09 06:12 PM
Posts: 1,646 Ringtown, Pa.
Dartsport540
Ringtown, Pa.
I run the FBO box, coil, and a recurved distributor. This summer was the 5th year running everything. I had a box and pickup go bad this year. I put a new FBO box and FBO distributor in it again. Also bought an extra, just to have, for spares.
548 cu. in., Bill Mitchell Aluminum Block, CRT 727 auto trans, Alston Chassis. 8.981et at 149.46 mph. 1.204et - 60 foot, So Far....
[Re: Chal340]
#240001
03/01/09 09:35 PM
03/01/09 09:35 PM
Posts: 1,554 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Man , I got the wole kit for my convert! Really apalling quality in the distributor....
Junk bent housing blasted to pee so the cap wouldn't fit. The star wheel wasn't pinned correctly and the star wheel was floating on the shaft. I was really surprised. They must have blind people picking the housings and assembling by my experience. I swapped to an accel cap, pinned the wheel correctly and the thing actually worked as ordered.
I'd buy MSD next time for sure!
1969 Hemi Charger R/T, 1970 Charger 472 Hemi 6 Sp 1969 Charger Pro Tour Project 1971 Barracuda Convert 1970 440 6pack Superbird, 1968 Fury I Police Pursuit 440 Super Commando 2 door sedan (Black/Blue) 1967 Barracuda Convert 1968 Barracuda Coupe 1972 Charger Rallye wanna be RT 1972 Sebring Plus 440-6 Clone 1969 Coronet Pro Street 2009 Challengeer SRT8 stick 1992-1986 Body 2500 4x4 440 stick 1982 Ramcharger 318 Sniper- getting enhanced. 1991.5 W250 Cummins- Big Chief
[Re: ademon]
#240003
03/02/09 01:10 AM
03/02/09 01:10 AM
Posts: 5,314 Carstairs, Alberta, Canada
dave571
Seems like a lot of guys with multiple fbo problems still buy from them, Why? is the spark from their box, coil and ballast stronger than my chrome box, msd blaster II, & msd .8 ohm balast resistor?
I'm surprised that there seems to be "multiple problems". I sold FBO for 4 years, and never warranteed a ecu.
The only issues I ever had, was the early FBO kits came with a poor ballast resistor.
As for why it's better than the blaster II with a chrome box, is the blaster II is intended for use with a capacitive discharge set up (like MSD).
Without that, it's output is nothing special. The FBO coil is setup for use with conventional spark system, so it's spark output is better.
The chrome box and the FBO box have very similiar specs when compared head to head.
[Re: Chal340]
#240004
03/02/09 02:41 AM
03/02/09 02:41 AM
RapidRobert
Quand j'ai tire mon roleau de FBO,l'ecu &(le depute) lestent le rouleau a commence a divulguer de l'huile de la tour immediatement donc je l'ai ferme.J'ai parle avec Don & il adit que j'avais besoin de serrer en bas la vis dans le haut auquel je l'ai informe que je ne savais pas que e'etait maresponsibilite des'arreter la fuite dans un(marquezle noveau rouleau) & quand je l'ai assure que le lest de depute que j'ai utilise etait plus d'ohms que son il m'a envoye un noveau roleau noir et un ecu gratuitement. je ne les ai pas utilises encore mais va dans plusieurs mois, je me souviens quand FBO a repris connaisance & a gagne un culte immediate suite a si beaucoup d'utilisateurs avait des rapports rougeoyants de comment don systieme a joue. J'ai entendu la voie plus bonne que mauvais & je verrai bientot pourmoi(la 2eme fois autorde de) le fait qu'il l'a rendu le droit(en includant l"expedition a fait un croyant de moi. Je me souviens vrainment il y a beaucoup d'annee de quelau'un critisized un des ses produits ou quelque chose & il a bascule avec la tirade la plus plus furieuse dont j'etais te moin jamais sur intermet. Je veux que se L'aire sauve comme c'etait vrainment une oeuvre d'art.
[Re: RapidRobert]
#240005
03/02/09 03:58 AM
03/02/09 03:58 AM
Chal340
FRANCE, Paris
You translated with google traduction? it's not very clear but i understood.;) thank you everyone for your answers.
[Re: dave571]
#240007
03/02/09 08:06 AM
03/02/09 08:06 AM
B5 Bee
Pangaea
Dave, My FBO gave me problems after I had it 1 year. It was already out of warranty by the time I got everything else on the car finished, so I didn't bother calling Don. The first problem was after about 200 miles. I think I had a bad FBO coil. It first went thru 2 ballasts, then the FBO ECU went, replaced with a MP chrome ECU, then another ballast, then the MP chrome ECU. Only thing left was the FBO coil. I replaced it with the cheap Accel coil I had laying around along with another MP chrome ECU, 3 years and 5,000 miles later it is still going.
Next time for me will be a Mallory HyFire 6, I think MSD products are overpriced.
[Re: 1MYTGTX]
#240009
03/02/09 08:16 PM
03/02/09 08:16 PM
Posts: 166 Caldwell. Id
edbux
Caldwell. Id
I also went thru a FBO ECU. It was replaced with less hassle than anything I've ever tried to return. This time I used a ground strap with it. Over the years, I've had a few ECU's die on me and they were all from Mopar On different cars). I think dying ECU's are something we are just forced to live with.
In FBO's defense, once I installed his system, my car started a lot easier. The distributor he curved really made a difference...to the good.That goes for the freezing winters here in Idaho. It replaced a Mopar Performance system.
Any more problems and I might just go to a dual point distributor. I kind of miss yanking out the distributor to install/adjust points. Also, I think my dwell meter is lonely.
1967 Dart 270
360/727
