Re: Silicone and sealers talk. Small block
[Re: RAY1969CARS]
#2398758
11/05/17 12:20 PM
11/05/17 12:20 PM
Posts: 716 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Valco Cincinnati All-In-One Aluminum Silicone.
The best stuff i have ever used!
Joe
Without Data, you’re just another guy with an opinion.
[Re: RAY1969CARS]
#2398865
11/05/17 03:00 PM
11/05/17 03:00 PM
Posts: 43,317 Bend,OR USA
Cab_Burge
Gas A Cinch (SP?) for sealing and sticking all the gaskets on except the head gaskets and rear main seals ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Adhesive silicone only for BB rear main seal holder to the block to seal up the side seals and in the corners of the intake manifolds and or valley pans ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif) Thermostat silicone on the water pump and thermostat housing gaskets ![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
[Re: Dave Hall]
#2398941
11/05/17 05:47 PM
11/05/17 05:47 PM
Posts: 17,926 Akron, Ohio
ProSport
Akron, Ohio
None of you use "The Right Stuff"? I used it for everything on my 400 and am super impressed with it. Not cheap though... Have you had to take anything apart yet? ![grin grin](/ubbthreads/images/graemlins/custom/grin.gif) It is really good stuff, just gotta be careful what you use it on, it almost welds parts together. I use Permatex Ultra black on most stuff, and the gray on parts that I don't want to take apart for a long time, it is fairly hard to get apart too sometimes on certain things.
[Re: RAY1969CARS]
#2399000
11/05/17 07:03 PM
11/05/17 07:03 PM
Posts: 11,743 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer Black Silicone (16B) over the Ultra Black. But I have been using the Gray more here lately, depending on the application. I'm not a big fan of smearing that stuff all over everything. Just a touch on the rear seal and rear cap joints. A dab in the corners of the pan gasket, end seal joints. The ends of the intake. Maybe a smear around the water passage areas of the timing cover if it shows any corrosion damage. That's it.
[Re: CMcAllister]
#2399015
11/05/17 07:39 PM
11/05/17 07:39 PM
dartman366
Mt. Vernon, Ohio
used the right stuff one time and swore it off the first time I had to dis assemble it, I think welding the intake on would of been easier to take off.
[Re: Dave Hall]
#2399047
11/05/17 09:09 PM
11/05/17 09:09 PM
Cab_Burge
Try removing the oil pan or valve covers or valley pan with that stuff on the gaskets ![hammer hammer](/ubbthreads/images/graemlins/custom/hammer.gif) It ain't right after all on them
[Re: StealthWedge67]
#2399058
11/05/17 09:27 PM
11/05/17 09:27 PM
Posts: 2,744 541 slobovia
A990
541 slobovia
The only thing I ever use anymore is Permatex Aviation Form-A-Gasket. A thin coat brushed on the gasket and allowed 10 minutes to tack up. There is a place for silicone from time to time, but this stuff works and stays tacky, never hardens. http://www.aircraftspruce.com/catalog/ep...ASABEgLSevD_BwE Is this blue? If so, I think Permatex used to call it Hylomar. It's the only gasket sealer I use anymore. Hylomar is still available, but comes from England and is pretty spendy.
[Re: RAY1969CARS]
#2399093
11/05/17 10:25 PM
11/05/17 10:25 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Permatex makes a sealer specifically for the chemicals in gear oil for rear end applications.
