Re: Silicone and sealers talk. Small block
[Re: RAY1969CARS]
#2398758
11/05/17 12:20 PM
11/05/17 12:20 PM
Posts: 714 Central TEXAS!!!!
sr4440
Central TEXAS!!!!
Valco Cincinnati All-In-One Aluminum Silicone.
The best stuff i have ever used!
Joe
Without Data, you’re just another guy with an opinion.
[Re: RAY1969CARS]
#2398865
11/05/17 03:00 PM
11/05/17 03:00 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Gas A Cinch (SP?) for sealing and sticking all the gaskets on except the head gaskets and rear main seals Adhesive silicone only for BB rear main seal holder to the block to seal up the side seals and in the corners of the intake manifolds and or valley pans Thermostat silicone on the water pump and thermostat housing gaskets
[Re: Dave Hall]
#2398941
11/05/17 05:47 PM
11/05/17 05:47 PM
Posts: 17,918 Akron, Ohio
ProSport
Akron, Ohio
None of you use "The Right Stuff"? I used it for everything on my 400 and am super impressed with it. Not cheap though... Have you had to take anything apart yet? It is really good stuff, just gotta be careful what you use it on, it almost welds parts together. I use Permatex Ultra black on most stuff, and the gray on parts that I don't want to take apart for a long time, it is fairly hard to get apart too sometimes on certain things.
[Re: RAY1969CARS]
#2399000
11/05/17 07:03 PM
11/05/17 07:03 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
I prefer Black Silicone (16B) over the Ultra Black. But I have been using the Gray more here lately, depending on the application. I'm not a big fan of smearing that stuff all over everything. Just a touch on the rear seal and rear cap joints. A dab in the corners of the pan gasket, end seal joints. The ends of the intake. Maybe a smear around the water passage areas of the timing cover if it shows any corrosion damage. That's it.
[Re: CMcAllister]
#2399015
11/05/17 07:39 PM
11/05/17 07:39 PM
dartman366
Mt. Vernon, Ohio
used the right stuff one time and swore it off the first time I had to dis assemble it, I think welding the intake on would of been easier to take off.
[Re: Dave Hall]
#2399047
11/05/17 09:09 PM
11/05/17 09:09 PM
Cab_Burge
Try removing the oil pan or valve covers or valley pan with that stuff on the gaskets It ain't right after all on them
[Re: StealthWedge67]
#2399058
11/05/17 09:27 PM
11/05/17 09:27 PM
Posts: 2,730 541 slobovia
A990
541 slobovia
The only thing I ever use anymore is Permatex Aviation Form-A-Gasket. A thin coat brushed on the gasket and allowed 10 minutes to tack up. There is a place for silicone from time to time, but this stuff works and stays tacky, never hardens. http://www.aircraftspruce.com/catalog/ep...ASABEgLSevD_BwE Is this blue? If so, I think Permatex used to call it Hylomar. It's the only gasket sealer I use anymore. Hylomar is still available, but comes from England and is pretty spendy.
[Re: RAY1969CARS]
#2399093
11/05/17 10:25 PM
11/05/17 10:25 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Permatex makes a sealer specifically for the chemicals in gear oil for rear end applications.
